  • 2 months later...
Would a ding like the one on this car prevent roadworthiness? The one on the back door most specifically, the paint would probably buff off.
cp5324997492350916733.jpg?height=700&asp
Edited by bucket_boy101
  • 1 month later...
  • 3 months later...
I've just bought an R34 GTT and I'm looking for some original rubber brake and clutch pedal covers for a roadworthy. I know in the past aftermarket bolt-ons have been denied, and I don't particularly want to pay $150ish dollars for genuine GTR ones. Any help would be much appreciated.
I spoke to the mechanic today who will be doing the roadworthy and he said bolt on type of pedal covers would need to be bolted THROUGH the pedals, not bolted on using brackets as most aftermarket kits have, or alternatively, grip tape/skateboard deck tape is acceptable, as long as the pedal has a grippy surface it will pass. So I spent $5 at a bike shop on a 90mm x 500mm strip of scooter deck tape. I'll have enough left over to re-cover both pedals 5 times over. He is also happy with coilovers as long as they are a quality brand (mine are Teins) and not a backyard job. Car is booked in for Monday, happy days!
  • 4 months later...
Got a question for everyone, i was in a quiet carpark tonight and was revving the car stationary a bit (its fairly loud) and a unmarked ford transit van pulls out of nowhere with 6 cops in it, two come out and say what the hell are you doing..
long story short they didn't check my license or anything.. just said your car dosnt sound normal I'm going to take your rego down and pass it on to a highway patrol to check over your car so expect a letter in the mail !!
Do you guys think the cop was bluffing? does a why patrol come to your house to check your car or? any help will be greatly appreciated.
there is nothing stoping a cop coming around and checking your car. strange if they had that much of a concern that they didnt get the HWY Patrol car to come there on the spot. but i suppose all you can do is wait now.
You'll most likely get an EPA notice in the mail, organised BY hwy patrol courtesy of him forwarding your details to them. Which means going to a noise test. Unless he got lazy later on or forgot about it, you'll get a notice.
I was in a quiet carpark tonight and was revving the car stationary a bit (its fairly loud) and a unmarked ford transit van pulls out of nowhere with 6 cops in it, two come out and say what the hell are you doing..
I would have said the same thing... :P
  • 3 weeks later...
Ok, so I tried to get a roadworthy today, and it failed because when you put the headlights onto high beam, the low beam lights switch off.
According to Vic RW standards, the low beams need to stay on when you're on high beam.
AFAIK, this is normal for the car, but the workshop guy said absolutely no room for negotiation on this.
WTF? Anyone had any experience with this?
uwot?
Skylines (and lots of cars) do this from factory... as you pull the stalk towards you, highbeams come on and then (less than a mm later) lowbeams go off...
I assume to limit power draw or overheating of the headlight casings?
They got complianced just fine like this...
I'd ask him to point out where in the Vicroads regulations it specifies headlights and high beams must come on at the same time. Nothing in VI26 stating that at all.
https://www.google.com/url?q=https://www.vicroads.vic.gov.au/~/media/files/documents/safety-and-road-rules/vsi26_1212_web.ashx%3Fla%3Den&sa=U&ei=a8xlVOGCCIO0uASmn4H4Dw&ved=0CAYQFjAA&client=internal-uds-cse&usg=AFQjCNGnCFP--oDZ6hARnPy2LHeNtUDf2Q
Nothing in ADR 46/00 about headlight/high beam coming on at the same time either if you wanted more proof that dude is talking out of his arse :P
http://www.comlaw.gov.au/Details/F2006L02294
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
