yes, a public carpark (eg shopping centre carpark) is considered a public road.
You can also be fined by the EPA for littering in public carparks.
Pretty much the only place you can do burnouts etc is on a private property or a private road eg out in the bush at your uncle's farm etc, OR at a motorkhana event eg DECA or at Calder Park Raceway drifts/drags etc.
https://www.sau.com.au/forums/topic/156277-hooning/#findComment-2903937
If i did a burnt out or whatever in a car park where no1 was there... and no1 could see... could they class that as hooning if i posted it on say youtube ?
SERIOUS QUESTION :ninja:.
If a tree fell in a forest and no 1 was there to hear it would it make noise.? (sorry had 2 say it)
As Kaz180 said public car parks an such even service station drive ways are main roads.
If you really have to do this i would use a couple of witches hats and do the burnout between
then to make it look like a controlled situation .But remember you may not see the police when you start but they might see all the smoke and come and have a look..
Its you call..
https://www.sau.com.au/forums/topic/156277-hooning/#findComment-2904110
They could class it as 'Idiot'...
Shouldn't that be " They could class you as an 'Idiot' " for asking that question....You wanna be a hero and put burnout videos on Youtube feel free do it in the middle of a city intersection just take your number plates off and they will never know it's you but remember to be hanging out the window giving the camera man a big smile and thumbs up so they can see exactly who you are :ninja:
https://www.sau.com.au/forums/topic/156277-hooning/#findComment-2904221
SERIOUS QUESTION ;).
You want to do a burnout, post it on you tube because you think people will think ur a f'n champion!! U idiot!
https://www.sau.com.au/forums/topic/156277-hooning/#findComment-2904605
+1 This is the sort of attitude we would expect from a Noble Park twat. ;)
Dear Moderator,
Things like this should invoke a strike against the user, for the simple reason SAU doesn't promote or endurse such behavior. To post such a stupid question should make that 2 strikes in my opinion.
https://www.sau.com.au/forums/topic/156277-hooning/#findComment-2904674
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
    • Quite right, typing without checking, it is an 023 which was effectively the replacement for 040 (not that I could find either of them on the Bosch motorsport AU site), and it has a mesh inlet at the bottom of the pump rather than a separate filter
