G'Day all.
Hope there are some people out there who have done this and can give me some advice. If I can get enough info I'll take a bunch of pics and do a Tutorial of it. I use to write tutes for a job so it shouldn't suck.
Anyway. These are what I have. I was told that the stock sensers would work, but I'm a little dubious.
I want to put there where the climate contrlls are and move them down and the stero down as well.
What now?
Thanks in advance for any info you guys have...
I checked on mine, and I didn't have the required harness connector for the gauge set.
You could chase each sensor wire up and splice it in. Shouldn't be too hard to do. volts comes from the supply to the gauge set, oil temp you could rig up from a sensor in a sandwich block, same with the boost.
Although why you would want to.. the volts is almost never used, first indication is headlight brightness. Boost gauge is the crud -7 to +7 one. and the oil temp gauge doesn't have a great resolution. Aftermarket all the way for better clearer gauges.
And damnit, it isn't a gtr, just adding gtr parts doesn't automatically make it better.
Have fun.
James.
    • Just to give an update coilovers passed without any issue!
    • Ducan , yeah sure mate , the unit is https://www.carlinkit.com/ambient TBox Ambient -  plugs straight into the USB C and it runs as a android  unit and you can link your phone to it via Bluetooth , but it only allows for one phone at a time. you can download and apk files you want and load it on there , I downloaded a basic maps apk (OsmAnd+ — Maps & GPS Offline) so I can run navigation without data usage , its not as good at google or wazes but it works fine for what I need. I can put up screen shots if you like. Cheers Pac
    • Hey Team , just got the Fujitsubo unit installed , not a big db difference but it does sound better across the rpm range , I have the front pipe on order I'll post a video with sounds when that has also been installed.
    • The gearbox in my R32 GTS4 (now with RB25DET) has just over 300k on it . Life includes some track time. Has had one change of oil in its lifetime. I rev match on down changes. I don't have any problems with synchros or gear crunching.
    • Currently advertised with some A4 flyers up at work for $30k ono Will detail it next week, and get some good picks for carsales, then put the cover back on and put it back on the tender until someone comes to look at it No real hurry to sell, in saying this I would like it gone with in 6 months as I am retiring in May 25 and lose the ability to store the car undercover in a secured site, plus as we are moving out of Sydney the potential buyers market will be more limited https://www.sau.com.au/forums/topic/485907-2002-vx-ss-commodore-30000-ono/
