Was speaking to a tuner last week regarding my car, and he suggested i remove the FMIC and replace it with a pipe straight from the turbo to the throttle body and have a water or methanol sprayer installed just before the throttle body that sprays in vapour to cool the air.
He said the actual device (sprayer) costs less than $50 to install and its far more efficient than a FMIC that has a pressure drop and is heated by the engine
Anybody tried this sort of setup at all?
To me it made sence sxcept for 1 thing, wouldn't spraying vapour into the air mean that the water will get inside ur engine and screw it up? He said that the water inside ur engine would be harmless, but im not sure about this.
  • Replies 55
No...it doesnt screw it up as it atomises as it enters the intake into the plenum. it cools the intake charge and the fuel also, drops the temps a fair whack so you can add more timing and boost without any dramas. Search for The Mafia + Boost Cooler for info on the setup he tried and alot of others also.
We use it on our race car with great success. Its water and methanol, i wouldnt take the intercooler away, leave it but add the injection on top, intercooler still does a descent job.
However, like anything it needs to be tuned.
I run water methanol injection.
ok here are a few tipes -
1. Find another tuner. THis guy has no idea.
2. A Decent Watermethanol kits is $800. There is no way you could get a kit for $50. What, a washer bottle pump and a few $2 hoses? SOunds like dead engine to me.
3. I run water methanol injection AND a Large FMIC. I spray the water methanol through the intercooler for more effect.
http://www.full-throttle.com.au/Engine/Boost%20Cooler.htm
it might be effective, even more effective on its own.. i can't answer that
but what i think is you've got to think practically here..
with a FMIC you bolt it up and walk away. every time you drive its always there doing its thing regardless of rpm or engine load
with a water/methanol injection, it has to be tuned to only come on at certain rpm/load. PLUS, you have to re-fill it all the time.
for me, practicallity and proven effectiveness of hte FMIC makes it the winner every day of the week
  • 3 weeks later...
http://www.snowperformance.net/products.php?p_cat=262
Buy direct and it may save you a few $$.
Thats if you can. :P
R33_racer, how do you go about tuning the water meth?
I've been reading a little and it appears you setup the afr's to 12.5:1, turn the water/meth inj. on and set that up to drop the afr by half a point. Then start pushing the ignition in to it.
Is that how yours is tuned?
Anyone know of kits around the $400 mark, I've only seen them for $600 and over. Seems a bit over priced for what they supply.
If you buy a cheap half assed kit, you will get a cheap half assed result.
$850 for a kit is not overpriced - Considering you get a Shureflow pump (worth over $300) wiring, 3 nozzles (these are top of the range nozzles) and a variable controller with inteligence built in. They creat a nice linear curve of pressure so that you aren't simply turning the pump on full at some pump making a dead spot visible.
They start at 0% pressure and work their way up to 100% depending on how youve adjusted it. Saves water and methanol too.
These kits also have a output for an addon called saftey injection. THis is hooked up to a solinoid, and is plumbed in around your boost controller so that if you run out of water, instead of your motor going bang, it opens your wastegate and runs minimum boost until you resolve the issue. It can also output to a haltek input which changes to less agressive maps...
Trust me, if you buy a $400 kit, you'll regret not spending that bit more.
Links to the kits?
Don't be lazy and read the thread?
Edited by The Mafia
Yeah, I've seen that site, it'll probably end up being the same price once you get it to your door step though.
Hmmmm wonder if you can use nitro fuel from rc cars in water injection...
you can use something similar that they sell. Not sure how bad of an effect it has on the motor though
Mafia... What do you think about buying from the US as it does appear cheaper?
The kits are the same brand etc. But do they contain the same gear?
They are a fraction cheaper, but they won't sell them to you because they don't like to undercut their australian dealers. I've tried it.
Trust me, best option is to grab one of Full throttle performance. Best $850 I ever spent. Oh, and you neer ever have to use octane booster again, and that saves quite a bit of money over time. I remember when I was buying drum after drum of toluene, that alone would have paid for a WM kit that would have been so much better.
Serious question Brett?
The concept of using water injection involves adding the fine mist to a hot intake charge, and the water absorbs the heat energy to convert to a gas (steam), thereby cooling the intake charge. More dense intake charge then allows tuning to make the power. Obviously there are benefits that adding a certain % methanol to the mix brings, but note people do not use 100% methanol. Water will accept/mix the alcohol but only to a certain extent.
I'm aware of some of the properties of nitromethane, but who in their right mind would try using that in a water injection setup? The risk of fire amongst other things is just a little high, and I'd be dubious how stable that commercial mixture is - ie. how fast would you have to use it once opened?
cheers
Dale
Edited by Dale FZ1
Cubes I think you'd find the AFR would become leaner due to the increased density of the cooler intake charge. Therefore you'd want to add fuel.
The slower burn rate should allow more advance to be wound in as you say.
According to the boost cooler forum the blokes there state it makes the afr read richer.
http://www.snowperformance.net/forum/viewtopic.php?t=569
You will want to set up your A/F ratio to around 12:1 without the methanol injection and stock timing.
Once that is set you enable the injection and A/F should richen up by 1/2 point for 50/50 mix. Then start to increase timing 2-3 deg at a time until there is no change in HP.
and..
http://www.snowperformance.net/forum/viewtopic.php?t=731
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
