Perhaps with a methanol mix, that is right. Obviously the meth combusts, which would skew the results vs using only water. I'm not going to contradict the observed experiences of guys who have used/tuned with it.
Two different approaches altogether, and would require you to use either one (100% water), or the other (water/alcohol mix) and stick with it religiously.
A friend of mine having his rally car tuned last week found that the AFR leaned off from 11.8 to 12.9 using 100% water.
  • Replies 55
To the original topic of the thread.
If I was going down the upgrade path again, I would probably look for a good quality SMIC to control pressure drop at higher boost, and avoid having to cut bar work to make a FMIC fit.
Then I'd also include a water/meth kit.
Overall cost would probably end up in the same bracket as using a good FMIC, but the results of the water/meth kit superior.
The question would be can you live with checking/filling the reservoir on a regular basis?
Edited by Dale FZ1
Yeh when ours was tuned they had to lean out the afrs a little....but then screw in heaps more timing and a few pounds extra of boost and watch the power climb with no increase in knock.
cool. as soon as i get my new alcon setup happening il be going down that path. seeps pretty good bang for buck.
also i would think thered be a slight reduction in turbo lag too. is this tru. cos of more stuffs going into the engine?
question for you guys: how long are your actuation paths for the water/meth kits?
I am probably going to install a decent kit on my vehicle eventually, but the reserviour would need to be in the boot of the car due to space constraints under the bonnet. would 2-3m of piping be okay? do they have check valves?
Stocky,
If you check out a couple of the links above there's a bloke with a kit behind his back seat. So I'd assume its all fine running a setup so far away. You can get check valves for them. Not sure if the kit includes it.
haha neill we run our tank right at the very back of the car in the driver side quarter panel/boot...no problems with ours. Its small quarter inch line with a high pressure pump...there is virtually no pressure loss over the few metre distance it covers, if your suspect about it just get the upgraded pump to the 220psi model.
Ive heard of some bloke who set his injection up two way...one feed before the throttle body as per standard and then he hooked up another one in his intake which was hooked up to a boostline from the plenum so it helped atomise the mix better and it cooled the compressor/intake air before it was cooled by the i/c and then even moreso when it reached the valve inlet. Supposedly it increased the hp rating of the compressor by another 100-200hp as it was cooling the intake charge right at the turbo inlet so its efficiency range could increase without blowing hot air...thats how it was explained to me anyway...ive never seen it myself....but i wouldnt mind trying it.
yeh more then likely. But extra timing adds a bit of power. If your knock is a little high at that level then it will come in handy just for reducing knock.
Edited by r33_racer
I am thinking of just buying a 100psi pump, a proper spray nozzle and using the signal from the stock boost solenoid to activate the water injection at 4500rpm via the use of a relay.
Anyone have any thoughts on this idea? I know it gives limited scope for tuning abilities, but it would reduce some of heat generated at higher boost levels.
I have a kit imported from the US. Works well however you need to tune around it. If you do not have access to a wideband then you are tuning blindly.
Btw water's effect on AFR is negliable and that is a fact.
Total agreement about the need to use wideband to tune.
Regards the effect on AFR, can I refer you to my earlier post about the impact on my mate's rally car during tuning? Going from 11.8 to 12.9 is quite significant. Note: that particular system used only water injection - no intercooler.
When tuning "around" the water injection, did you play mostly with fuel, or ignition?
cheers
Edited by Dale FZ1
well the kit we use states that you need to lean out the mixtures by around 10% i think it says from memory. Apart from the kit, our tuner also stated that he had to lean it out as it was too rich and flat spotting if he didnt.
water/methanol kits are as old as the hills and they don't cost a fortune to make yourself if you have the time and can be bothered.
You 'can' remove the air to air intercooler if you are drag racing and just the injection kit but, you might also like to switch instead to a water/air intercooler.
Tuning wise you end up with an interesting mix of changes depending on whether you used the kit to nab more boost, timing or leaner AFR or the usual combination. From memory (although someone correct me if I am wrong) the 'ping' threshold is lower with the water injection effectively acting better on hot spots in the combustion chamber as opposed to an air temp drop of equivalent magnitude (waters specific heat value is rock & roll compared to the gas components in air). I vaguely remember conversation (alcohol and years of brain damage) with drag racers years ago at the old ravenswood drag strip about humidity and it's effects on the tune for supercharged engines.
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
