Hmm all I know is it will be showing between 0.1 - 0.9v on idle as if shifts from rich to lean.
Don't know if ohm will effectively show anything
cheers mate, just to clarify the diagnostic issue the plug to do it on is just under the drivers dash on a clip type setup? also i have to short the two wires that state chk and ign? i thought doing that just cleared the error codes? its not as easy as the VL setup i used to do maybe im just getting stupid. cheers in advance. :huh: i am :angry: if you can be bothered any chance you could step by step instruct me,
Edited by STLKHR
cheers mate, just to clarify the diagnostic issue the plug to do it on is just under the drivers dash on a clip type setup? also i have to short the two wires that state chk and ign? i thought doing that just cleared the error codes? its not as easy as the VL setup i used to do maybe im just getting stupid. cheers in advance. ;) i am :sleep: if you can be bothered any chance you could step by step instruct me,
Yeah a brief short will start the diagnostic mode, shorting again will clear it from memory.
And yeah that's the plug, with the cover attached to it, clipped underneath.
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
