Suspension Workshop/info Night At Heasmans - Bilstein In Sydney
Beer Baron
  • Replies 154
You're up to 30... does that mean its now full? I'd like to attend. My car has been at Heasmans for two weeks, should get it back tomorrow. New upper control arms, castor bushes and reset springs. Cant wait to drive it again!
Hi guys. yep we have 30, but no, not full yet. I'm anticipating some people will end up pulling out, or not showing up on the day as plans change etc. so I'm happy to put more people down. Also, 30 is not a hard cut just the ideal number as we don't want to group too big.
allblanct and Mr kotter added.
marcus32, I'd love to add you mate, but this event is for SAU NSW financial members only as it's organised for the club. BUT you are most welcome to join up, even join up on the night if you wish. Apart from events like this one there are lots of other benefits to being a SAU NSW member (discounts at stores, discounts on merchandise, use of our nissan pricing etc).
LOL
:P
*memories
:laugh:
Richard, put me down as a yes for the time being.. :laugh:
Vic! Long time bro. Havent seen you post in a while. We were hard pressed for tools at the time and getting desperate, and I want to buy you a replacement plug cover if you havent done so already :D
I should harden up and buy memebership, ay.
lol, screw targa duncan. i'll see you there. :D
yes, it looks like we will have a nice turnout. great to see so many people interested in learning something about the dark magic of suspension tuning for performance applications!
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
