When I was in the market for an EBC I found this article helpful > Electronic Boost Controllers Comparison <
My mate has the Blitz ID-3 & I think it's still one of the bestest EBC's around but, with that said I have the more simpler GReddy Profec B-Spec II. I chose this purely for the wank factor of the optional wireless remote switch :iluvff: & it does the job wonderfully.
i have a (HDI) hybrid electronic boost controller, just high and low but boost can be adjusted in cabin... it uses the same solenoid i've noticed as... apexi & turbosmart... thats all i've noticed from looking.. its a mac solenoid and the solenoid is only worth $60 lol can you belive that shit? but i suppose the electronic components in the actually controller is what counts but so far so good... Holds boost no problem and its the best $250 i've spent.. just dusn't look like the prettiest thing in the world lol
I have a kiwi boost controller. the gizmo, it's electronic and you can set it for 4 separate boost levels. it only cost me $350. so it's pretty cheap for electronics. Now I just need a better turbo to warrant having 4 levels of boost....
I have a HKS EVC (Electronic Valve Controller) on my grey GTR that supposedly improves midrange and responsiveness of the RB26 as well as acting as a boost controller. It certainlly comes on full boost earier (~1000rpm) than my white GTR which uses a GReddy Profec B.
Cheers for all the replies! For those of you that have the GReddy Profec B-Spec II would you consider to be a great buy? I was just thinking, since im a while away from actually upgrading the turbo is it worth me getting something like the Blitz ID-3 controller?
Any thoughts appreciated!!!
I own a profec spec b 11, its a great buy! Have a look at www.performancewise.com.au he's good to deal with, does specials for sau!
Yeah OR for a manual one that ONLY costs like $30, go for the turbotech, mine has worked excellent since i bought it and very easy to adjust. :angry:
i also have the turbo tech same with my mate whos got a Mx6 hes put his in the cabin so he can change boost on the fly :huh: i will do the same one day
yeah same here i put one in my mx6, it's cheap and easy to install! but i need a stupid fuel cut defender! i can only jack it up to around 5-6 psi at the moment because my intercooler brings in too much air! with a stock intercooler it can be boosted to around 10 psi before the fuel cut sets in!
if you want i can hook you up with a dude that can retune your ECU and gets rid of those :huh: pluss has a better tune for $250 my mate got his done and no anooying beep when boosting high
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
