Dyno Tune - Thanks. Now Need Someone To Buy Touch Up Paint Off. Calsonic Blue.
Just finishing putting all the new stuff in my car. Who should I go to on the coast?
Was thinking Gavin Wood? Good choice?? or who else?
Thanks guys
Rather than starting a new topic - I thought I'd just post this here.
I'm now looking for someone to supply/apply some touch up paint.
Any ideas?
Edited by Anakha
heard nothing but good things about matt. will be going to him when i get my SAFC2 tuned (waiting for cash >_<)
1 thing to remember: i've heard his dyno is a tad on the conservative side.. so don't worry about the figure it spits out, just look more at the before / after curve.
I got my PFC in now, in need of a tune. Stock maps Okay, but it could be better, a little more grunty in the low and midrange and about the same as stock up high... injector duty never go's above 40% on 0.9 bar so im questioning if I have the stock injectors in there...
anyway I might give matt spry a ring, would be good to get done before dyno day.
Already called him last week as a back up plan incase Richard cant do it...
2-3 week wait... Cannot do it before the dyno day... :huh:
The soonest he had free was the day of the dyno day... :)
whats matt charge these days? Is it still the $200/hour? That, in my books is a flamin rip off. A fair few people on here go to richard at Allstar Tuning. What's richard charge $/hr col?
Richard was $100 per hour
And for that price he (Matthew Spry) will happily lock your PowerFC, so that nobody else can tune it.....
thats 50% less than anyone else I know of
damn straight it is! damn richard and his awesome business, if only i knew all this earlier *sigh*
bahaha yeahhhhhh :D
You would have to ask him what his usuall rate is, but yeah SAU members get on the rollers for about $100 an hour...
Yep, only for members tho...
:D get farked!
True...
Yes, but in Matts defence he asked me when he tuned mine if i would like him to lock it or not.
He expained if he locks it then people stuffing with the hand controler wont do any damage, he went on to say he is happy to unlock the pfc free of charge if nessary in the future... I saw the benifit of locking the pfc...
What if you wanted to change some parts which required corrections to the PFC? eg; injectors or AFM. That would mean you would have to drive all the way to the coast to make an adjustment that would normally take about 20 seconds. I don't see any benefit. I don't leave my car with monkeys, so nobody is ever going to be "stuffing" with my PFC.
Say you did leave your car with a workshop that you were unfamiliar with and you wanted to set the limiter to say 4000rpm just to be on the safe side, no can do without a trip to PITS....
    • Not sure if this helps but I had a similar issue where one of the doors wouldn't lock unless I pressed the lock key twice. Turns out the door actuators were f**ked. In the Nissan service book it says to lube it every now and again, I guess put a bit a bit of wd-40. I replaced mine and haven't had a problem since.
    • 2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
    • After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
    • The one door lock not working intermittently sounds odd. But for the other issues I'd suggest to clean the contacts and everything on the little board inside the fob. I had the same issue with unlock working but not lock, and that solved it. It brings such a quality of life change to be able to lock and unlock the car like a normal person
