HRMMMMM Interesting views....Im in the same boat. Ext. gate to atmosphere, but what to run from the turbo back, Im probably not going to use a cat, so either 3.5" from turbo back or 3" turbo to "where the cat should be" then 3.5" "cat back" so to say.......Opnions?
This is for 260 (street) and possiably 300rwkw later on.....
Remember Roy Atmo Gate = Love
  • Replies 52
I want to make my car legal and pass the epa tests etc. So because the flex pipe they used on my external gate plumb back is leaking i might remove it and run a whole exaust to the back of the car and use a small cat so the epa cant whinge about it.
Not saying it wont make the power, i did ;)
The 3" system i had on my car, definately was a problem as the gate had to stay external
Then, my exhaust goes up and over the diff, where most R33's seem to be pretty straight and go under it.
Seen a couple of cars go from 3" to 3.5" and pickup some excellent results.
Nothing beats a flowing exhaust.
I have been warned though that this year i may be getting pinged at track days as the EPA are enforcing db requirements at the track. Now i dont care about losing the cool noise at WOT, my concern is will the increased gas flow in the exhaust cause back pressure problems...loss of power/boost problems etc?
Anyone had a plumbed back vs atmo experience on the same car, setup and tune? I know of two cars that lost power when they were plumbed back. Is that the norm?
I am running a high flow cat and HKS Hyper exhaust, which has two mufflers. Will it handle all those by-passed gases?
Hey,
I have only anecdotal evidence from a friend (seat-of-pants) that says yes, performance will drop.
When you plumb it back you're attempting to stuff extra gas through the system - more backpressure, less performance.
So the same car, same tune is almost guaranteed to lose performance from changing VTA to plumb-back and nothing else.
"How much" performance drop really depends on how much your exhaust 'can' flow vs how much it 'is' flowing right
now, and how much gas is chucked out the gate that needs to be accounted for. I'm not familiar with that HKS exhaust
nor the internal design of its mufflers, but if it's 3.5" or bigger I'd say it will probably be OK.
You could always knock something up and see ;) If there's a big difference you'll probably hate it and take it back off;
but then at least you can take it to the track ready for fitting if you do get pinged...
Regards,
Saliya
'zackly- you can't beat physics
even the Ferrari F40 runs a screamer from factory!
turbo cars will always make the most power with as little back pressure after the turbine as possible....shame though that the RTA/EPA aren't concerned with your rwkW figure ;)
i used a slip joint. no clamps and it doesnt leak and is nice and compact :)
Mine's plumbed in. 3 inch off turbo to cat. 2 inch off 38mm gate to cat. 5 inch metal cat. 3.5 inch cat back. good for 288rwkw so far.
I can't give a true back to back plumbed vs atmo vented as i had the metal cat installed at the same time i had it all plumbed up. I also had it all done pre tune and pre cams when the car was making a touch over 200rwkw on 1 bar.
If you want to be a bit more scientific about it, plumb a pressure sensor where the O2 sensor is temporarily and check the backpressure on full tilt. I guess if its more than a few psi then there may be some perfomance loss.
I have already checked the exhaust pressure when i changed from 10cm housing to 8cm housing. Wasnt overly different which told me that the 8cm is right and the 10cm was jsut too big for the flow of the lil RB20.
I dont want to spend the money on labour por waste my own weekend trying this if i can reasonably identify it being a problem. I have a feeling i will need to go to a bigger exhaust which sux cause odds are it will be louder then what i currently have, only the gate will be silenced. At the moment off boost my car is nice and quiet .
Its a race track for gods sake...if residents dont like the noise dont farking move there, :wave:
If you checked the exhaust backpressure post turbo ie dump pipe, the turbine housing won't affect it much........unless you are saying you measured the backpressure in the exhaust manifold itself?
  • 1 month later...
Well the wheel has turned and i got done for noise. So need to do it. My dump pipe is pretty shitty and have never been happy with it.
So im thinking i may do a 4" dump pipe and tee the wastegate in just before i reduce down to the cat and HKS Hyper exhaust.
Do you think runn the larger diam dump will help with dropping gas velocity so a branched joint for the wastegate gasses wont hurt power as much? Can anyone confirm where the HKS Hyper exhaust sits with regards to performance and noise?
Is it a performance exhaust, street eshaust etc? Would it be the same diam with same mufflers as the Hyper exhaust on the GTR? Can i run a GTR exhaust on an GTSt?
I've got a HKS Hyper but with a single 5" cannon tip. Mine has an adaptor that you can put in the cannon tip to 'choke' it. I've never used it, but it would be good to go if I was ever done for noise.
HKS Hyper exhausts I thought were 90mm outside dia. so yeah, 80-85mm ID. Cos it's a straight through pipe from the cat, and given the diameter etc I'd have thought it was a pretty good performance pipe, I've never had any issues yet but I was only running with 240, now I'm aiming for sub 300 and I guess I'll be testing the bounds [3076, hks cast low mount, hks std wg, custom dump front plump back and custom s/s intake eventually].
BTW the exhaust has a good deep note, but is pretty quite really, I don't get headaches on long trips :dry: .
I got mine as a screamer wouldnt have it any other way, nothin beats the sound of an external gate goin nuts
Its not the point. Keep it off boost and there is no problem driving it on the street. But when at the track you want to be able to give it some stick without fear of being kicked off the race track. Thats is the real concern, owning a club car that is fun on te race track, that you pay lots of money maintaning and entering in events only to be kicked off the track :dry:
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
