rb25_gtst Posted February 14, 2007 Share Posted February 14, 2007 Hey guys, I'm just wondering who amongst all of you has had their car tuned by Advan Performace in Silverwater. Reason I'm asking is after they tuned my car I have been experiencing high levels of engine knock, high as in the hundreds according to the Power FC hand controller, and my ignition timing is at 42 degrees which I have been told is extremely high. I have had the engine compression tested, result was 145 across all cylinders, car doesn't blow any smoke or make any strange noises. The drive home Advan the knock level did not exceed 22, then the following day I think it went up to 120 something, highest reading from the hand controller was 200 and something, I'm hoping it's a faulty knock sensor or something. Hasn't seemed to damage the engine at all. So I'm just trying to find out if anyone else has had a problem with their tuning. I'm thinking of taking it to CRD to be retuned. Any suggestions or input is appreciated Thanks Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/ Share on other sites More sharing options...
R31Nismoid Posted February 14, 2007 Share Posted February 14, 2007 With a power curve like that. I would be taking it back and asking for a retune, or alternatively something might be wrong with the car, part not 100% or something. The curve is all over the place. Not what a good tune should look like Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2906831 Share on other sites More sharing options...
rb25_gtst Posted February 14, 2007 Author Share Posted February 14, 2007 I knew I should've taken it to SAS in the first place. One of the guys from SAS told me that Advan don't even have a proper tuner working for them, said they specialise in "bling" only. Any idea what part might not be 100% to 'cause that sloppy power curve? Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2906839 Share on other sites More sharing options...
Guilt-Toy Posted February 14, 2007 Share Posted February 14, 2007 that is f**king horrible! I street tuned my own car and the curve is 100% better then that crap - i hired a dyno the week after to get a couple of power readings and this was one of the runs.. totally different. How much did the tune cost you ? I cant believe they let a car out like that. Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2906986 Share on other sites More sharing options...
paulr33 Posted February 14, 2007 Share Posted February 14, 2007 the tune looks fine the top higher power run is the "after" dyno plot the lower one is the "before" dyno plot if its knocking a bit more than 60 then you just need to spend a few minutes getting accustomed with knocking and how to correct it. the pfc faq (in my sig) will tell you in great detail how to work with knocking and debug it correctly. read that and it will help you sort out the knocking Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2907009 Share on other sites More sharing options...
Spook's_Skyline Posted February 14, 2007 Share Posted February 14, 2007 er, i wouldnt be doing any fixing yourself at all (regardless of how easy it is after reading the faq) id be taking it back and telling them its knocking and make them fix it Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2907023 Share on other sites More sharing options...
Guilt-Toy Posted February 14, 2007 Share Posted February 14, 2007 Look at the power surge between 130 - 145 - that looks like something that would happen with rich and retard not with a full power Fc tune. I would like to see the ignition map and fuel maps of this tune.. there must be a reason why its doing that.. if its not the tuners fault then there must be something wrong with something there. the tune looks finethe top higher power run is the "after" dyno plot the lower one is the "before" dyno plot if its knocking a bit more than 60 then you just need to spend a few minutes getting accustomed with knocking and how to correct it. the pfc faq (in my sig) will tell you in great detail how to work with knocking and debug it correctly. read that and it will help you sort out the knocking Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2907059 Share on other sites More sharing options...
raz0r$harP.UK Posted February 14, 2007 Share Posted February 14, 2007 Yep I'd give Advan a call, speak to the owner (Peter) if need be, just explain it to him and see what he has to say. Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2907074 Share on other sites More sharing options...
Jordan Posted February 14, 2007 Share Posted February 14, 2007 Yes, even if you approach the ACCC for help, they will always tell you to go back and seek a resolution with the service providors. Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2907199 Share on other sites More sharing options...
Beer Baron Posted February 14, 2007 Share Posted February 14, 2007 before getting carried away with taking it somewhere else, or accc etc. just go back to advan and tell them your concerns... at least give them a chance to help you out. I'm sure if they did make a mistake, or possibly something changed on your car since the tune they will be happy to take a look and at least diagnose the problem (if there is one) for you. Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2907288 Share on other sites More sharing options...
Gazee Posted February 14, 2007 Share Posted February 14, 2007 ^^^ I agree with that... if they screwed up go back to em and see what they have to say about... but 43 degrees of timing is faily high isn't it? standard is like 15 or something like that.. according to the sticker on the bonnet... Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2907325 Share on other sites More sharing options...
Guilt-Toy Posted February 14, 2007 Share Posted February 14, 2007 Some workshops are really good to there customers - i know if it was Turbotechnics in newcastle they would put the car back on the dyno and double check it and fix it if they can for free. I hear lots of good storys about advan so i wouldnt be suprised if they do that for you too. Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2907326 Share on other sites More sharing options...
WPN-O33 Posted February 14, 2007 Share Posted February 14, 2007 I knew I should've taken it to SAS in the first place. One of the guys from SAS told me that Advan don't even have a proper tuner working for them, said they specialise in "bling" only.Any idea what part might not be 100% to 'cause that sloppy power curve? Hey mate, I had my car tuned by SAS a month or so ago and they did a great job. Good blokes, especially Rodney real helpful, i would recomend them to anyone they are straight talkers... Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2907331 Share on other sites More sharing options...
32vspecII Posted February 15, 2007 Share Posted February 15, 2007 i wouldnt be to concerned what the guys from one workshop said about another . your chart looks ok , not great but ok and you said it drove home fine i think something else is wrong , lots of timing advance will cause detonation and something is f**kign that uo Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2907377 Share on other sites More sharing options...
2rismo Posted February 15, 2007 Share Posted February 15, 2007 Step 1/ Take it back to Advan with your concerns and have them addressed Step 2/ There is no "Step 2" until you've done "Step 1" Adrian Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2907429 Share on other sites More sharing options...
Blitz Posted February 15, 2007 Share Posted February 15, 2007 Yes, even if you approach the ACCC for help, they will always tell you to go back and seek a resolution with the service providors. Lets not jump the gun with suggestions of involving the ACCC, thats ridiculous Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2907439 Share on other sites More sharing options...
paulr33 Posted February 15, 2007 Share Posted February 15, 2007 its really not a big deal, 42deg isnt much of a concern im up near 50deg on my tune and it rawks if its just knocking in one or two spots use the pfc faq to help work out where in the maps it is and then goto advan and ask them to kindly sort it out every tune knocks differenelty on the street with the owner dirving it compared to being on a dyno in a simulation. happens and just needs a quick touch up once its out of the simulator and in the real world Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2907459 Share on other sites More sharing options...
GTR-Dad Posted February 15, 2007 Share Posted February 15, 2007 I have been experiencing high levels of engine knock, high as in the hundreds according to the Power FC hand controller, and my ignition timing is at 42 degrees which I have been told is extremely high. I have had the engine compression tested, result was 145 across all cylinders, car doesn't blow any smoke or make any strange noises. The drive home Advan the knock level did not exceed 22, then the following day I think it went up to 120 something, highest reading from the hand controller was 200 and something, I'm hoping it's a faulty knock sensor or something. Hasn't seemed to damage the engine at all. As Paul said, knock over 60 is something to be concerned about. 120-200 would sound like someone pouring a bucket of gravel under your bonnet. If you heard abnormal sounds, it's probably knock and should be dealt with. If you didn't hear it, it's probably a bad sensor. If it IS knock, it could be a caused by a bunch of things, some of which are not the tuner's fault, but most of which probably are. Try some fresh gas before you get too worried. I wouldn't hesitate to fix it myself, but I like that sort of thing. If you paid someone to do a job, give 'em a crack at fixing it. Good luck! Dan Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2907672 Share on other sites More sharing options...
rb25_gtst Posted February 15, 2007 Author Share Posted February 15, 2007 Cost me $3000 for the Power FC, Z32 air-flow meter and the tune which means I paid over $1000 for a dodgy tune. I'll get someone to check out the sensor. I don't think I'll go back there, they seemed kind of hostile towards me. I have a friend who highly recommends Powertune in Fairfield, and from what I have read on these forums, they're not so good, but my friend assures me they can do just as good a job as Unique Autosports. Anyone on here had experiences with them? Thanks for all the help. Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2908479 Share on other sites More sharing options...
Munkyb0y Posted February 15, 2007 Share Posted February 15, 2007 man, you already paid for the tune. take it back and have them fix it. why would you walk away from 1k without even asking first? Link to comment https://www.sau.com.au/forums/topic/156411-who-has-had-their-car-tuned-by-advan-performance/#findComment-2908527 Share on other sites More sharing options...
