r33_racer Posted May 15, 2007 Share Posted May 15, 2007 i also use a kempi tig....they are top shit. Good to see that atleast someone on here knows a little about pipe purging to protect the root peno from contamination.....not many people are aware of it and why its done...good work troy. Welding whilst sitting on a good level bench is awesome for nice welds. Try welding pipe in the 5g position. My neck and back are killing after the root run and hot pass, let alone a few capping runs. Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-3120345 Share on other sites More sharing options...
Craved Posted May 16, 2007 Author Share Posted May 16, 2007 Michael, Have you tried a product called "solar flux" ?? it seems widely used in the US as a paste flux purge to use on the inside of pipe welds where purging the entire pipe is either not viable or will waste a large amount fo gas .. been trying to find it here in AUS but none of my welding suppliers have got it. Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-3121692 Share on other sites More sharing options...
r33_racer Posted May 16, 2007 Share Posted May 16, 2007 no i havent chris. haha i know the theory and prac behind purging....but ive never bothered myself, not unless i was making something and it was specifically required. The closest thing ive done when doing exhaust and i/c piping is stuff rags in the ends of the sections im welding to stop air running through the inside and contaminating my weld area. I suppose thats a basic form of purging if the gas was filling the section through any root gap i left. Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-3123040 Share on other sites More sharing options...
Craved Posted May 16, 2007 Author Share Posted May 16, 2007 yeah fair enough, i have the y adapters and stuff at home, but atm the cost of GAS overrides the need for true purging ... all the exhaust work i have dont has been section cuts for wastegates - which i die grinded after each section was welded one.. making it smooth internally Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-3123116 Share on other sites More sharing options...
r33_racer Posted May 17, 2007 Share Posted May 17, 2007 if your good enough you dont get any real peno sticking through and dont need to grind it out For most piping on cars the strength isnt needed like it is in a structural job. If you can get it aligned spot on and dont get any peno it makes the job that little bit quicker and easier. Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-3126203 Share on other sites More sharing options...
Craved Posted May 18, 2007 Author Share Posted May 18, 2007 yeah your correct, but there is always that one spot that doesnt play nice .. then you get the small balls on ths inside from the penetration .. never very much though Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-3128015 Share on other sites More sharing options...
mr_rbman Posted June 3, 2007 Share Posted June 3, 2007 i also use a kempi tig....they are top shit. Good to see that atleast someone on here knows a little about pipe purging to protect the root peno from contamination.....not many people are aware of it and why its done...good work troy. Welding whilst sitting on a good level bench is awesome for nice welds. Try welding pipe in the 5g position. My neck and back are killing after the root run and hot pass, let alone a few capping runs. haha, ye the 2g i aced but the 5g was a bitch.! Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-3158880 Share on other sites More sharing options...
ylwgtr2 Posted June 26, 2007 Share Posted June 26, 2007 (edited) I got an Essetti machine......Try taking the coke can challenge Edited June 26, 2007 by ylwgtr2 Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-3198908 Share on other sites More sharing options...
Roy Posted July 13, 2007 Share Posted July 13, 2007 I got an Essetti machine......Try taking the coke can challenge Smart ass. Nice work...now make me some stuff to make my car go faster! Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-3228303 Share on other sites More sharing options...
r33_racer Posted August 17, 2007 Share Posted August 17, 2007 next time im bored im going to tig two cans together....they had one at tafe welded at the bases. Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-3293952 Share on other sites More sharing options...
Craved Posted August 17, 2007 Author Share Posted August 17, 2007 next time im bored im going to tig two cans together....they had one at tafe welded at the bases. just thinking about doing that is hard lol what filler would you use thats thin enough to melt before you blow a hole in the can? Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-3294606 Share on other sites More sharing options...
Adriano Posted August 18, 2007 Share Posted August 18, 2007 When i was at Meadowbank Tafe a few years back doing panelforming at night, there was a night mig/tig course. Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-3295588 Share on other sites More sharing options...
ylwgtr2 Posted August 20, 2007 Share Posted August 20, 2007 welding at the base is easy...try the wall...it measures .1 thick Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-3297879 Share on other sites More sharing options...
r33_racer Posted August 30, 2007 Share Posted August 30, 2007 exactly the reason why i insist on the base...i would need a major stash of cans to get that one right and a butt load of time. Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-3317969 Share on other sites More sharing options...
mark32gts-t Posted February 22, 2009 Share Posted February 22, 2009 might be a noob question but anyway. I've seen electrodes for an arc welder that are suitable for stainless steel. Is it possible to weld stainless with an arc welder? Anyone tried it if it is possible? Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-4439807 Share on other sites More sharing options...
femno Posted February 23, 2009 Share Posted February 23, 2009 yes you can weld ss with arc. btw this thread is 18months old! Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-4441082 Share on other sites More sharing options...
Craved Posted February 23, 2009 Author Share Posted February 23, 2009 better to re-use this thread than make new ones, this SS ARC welding is with stainless rods? no point welding SS with mild steel Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-4441789 Share on other sites More sharing options...
The BOP Posted February 24, 2009 Share Posted February 24, 2009 might be a noob question but anyway. I've seen electrodes for an arc welder that are suitable for stainless steel. Is it possible to weld stainless with an arc welder?Anyone tried it if it is possible? Yep your lookin for 316L electrodes or better, the rule of thumb is whatever material your welding always at least match or better it. Best you just tig it much better in every way Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-4443499 Share on other sites More sharing options...
VB- Posted February 24, 2009 Share Posted February 24, 2009 not if you can't tig weld ^ or dont have a tig welder Link to comment https://www.sau.com.au/forums/topic/156412-welding-101/page/3/#findComment-4443665 Share on other sites More sharing options...
