I really don't know if you know what you are talking about Regan. I have a friend who has been fitting body kits for years....especially Skylines, and the idea of putting an after market frontbar on is so that it looks different to other Skylines. He says that of course you have to cut the support bar to fit them because THEY ARE DIFERENT! If you don't want to cut the support bar then don't fit an after market frontbar! I also see in one of your posts (see following post) that you sell a frontbar THAT YOU HAVE TO CUT THE SUPPORT BAR!! So obviously you think its OK to cut them, BECAUSE YOU SELL THEM.
regan
Newbie
Car: soarer
R33/Nismo bar
Hi
The front bars are $580.00 incl GST freight to Melb would not be cheap @$80-120 I think ,
Note*** these bars do require some front crash bar modifications to fit and would need some additional supports to be fitted.
Cheers
Regan
My friend also says that he doesn't fit small support struts underneath as it makes it even more rigid which does greater damage if you run into a kerb. Without the support struts there is more give allowing it to flex a little when you hit something. Fibreglass frontbars are so light that they don't need many bolts/screws to hold them on anyway.
Jim
https://www.sau.com.au/forums/topic/15642-body-kits/
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
