hi guys im interested in how my car would go by if im selling ..
just wandering what kind of price range would i be looking at ..
s14 s2 1999 luxury model
ASKING PRICE = 16k
mods =
650cc injectors
bigger fuel pump
exedy extreme cushion hd clutch
Down pipe and extractors on a HKS 2540 turbo
full cat blitz exhaust
dump pipe
hybrid FMIC
z32 airflowmeter
hks SSQ BOV
apexi avcr
lightened flywheel
full exhaust highflow cat
GREDDY e-manage piggyback ecu
ext. =
x-racing front bar
x-racing rear
x-racing sideskirts
car is naked fully debadged
genuine gramlight rims
full luxury sunroof
power everything
jvc headunit
thats all i can think of atm just wandering what kind of price range i would be looking at without a motor in this car am interested to sell as it is without motor .. the car ran 210rwkws have time sheet to prove ..
midnight blue in color body in imac condition
i am located in melbourne car has 12months rego
please contact me via email/msn [email protected]
or pm me on sau.com
mobile - 0421869074
note - am selling without motor but i can supply motor and would sell for more cheers
interested in swaps or sale ..
here are some pics - the back spoiler has been taken off and rear has been debadged.
Edited by kaecha
https://www.sau.com.au/forums/topic/156435-s14-s2-1999-luxury-model/
Potential buyers want to see what it looks like now, not at some past point in time. Would be a good idea to post some current pics.
car looks as it does in the fotos just without the rear spoil and rear has been debadged.
thx
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
