Sorry if you took it to personally but have you done a 2jz conversion on a skyline?
Have you built motors?
How much experience do you have with rb's or even 2j's for that matter?
What do you do for a living, is it automotive based??
10-15k on a rb hybrid to make the same power is that besed on the fact you own a part store, or have sone these engines before?
This forum is over run by people who make statement sbased on there own opinions and no real experience (what they have read or the mates have told them) and by people who are not remotely qualified to make stupid generalisations , which is basically what this entire thread is....
Sorry to say it but it grinds my gears that theres is endless arguement about unqualified statements such as "2j head is shit" or "rb30's arent a race motor" etc... Its almost to the point where you most people with true knowledge (not saying myself by any stretch) are turned away cause they are sick to death of the dribble.
Just read my thread looks like I am having a massive go at you, sorry mate, not my intention. Seroiusly though all i ask for is when people make statements they qualify there statement with experience and genuine facts that is all, sure it is a discussion forum and people have a right to opinion and heresay, all people need to do though is make it clear when this is the case!!!
Edited by Fitzpatrick Speed Works
$4,500 for a 2J
Then the gearbox. Priced the good 6 speed boxes for a 2J, they're nearly that price again.
Then get all new mounts and everything made, and then, since it's not the original motor in the skyline, around another $1000-$1500 or so for an engineers cert.
I'd be assuming the 6 speed box for the 2J has now come down from 6G (Where it was around 3 years ago) to a price of around $4000
So that's $8 500 JUST for an engine and gearbox, no mounts, nothing, not even in the car, you haven't even put a new turbo or anything on it.
So, looking at $9 500 basically (Excluding labour and engine mounts) to put a 2J in your R33.
You said $10 000 to $15 000 for an RB26/30 combo? I'll go a 26/30 combo then. As for $10 000 - $15 000 that's all new turbo, manifolds, injectors, etc, whereas, your 2J is still on stock turbos.
He's got a choice - spend well over $10,000 on a RB26\30 or spend less than that for a motor that can do the same, standard setup.
You can get a well built bottom end be it rb25/26 or 30 for around 3k. Drop in a set of forged pistons and rods, thats bumps the price up to 5k. Cams and springs, 6.5k. Add an ati balancer - 7.5k.
Unsure with the 26's but the 30's have issues with more than 7500rpm when making 700hp, the stock girdle needs beefing up.
I know of a 2jz that just let go with ~450rwkw. Smashed ring lands. :)
It is thrashed daily, especially on the weekends.
I bet that wasn't the engines fault...
Well, I had no idea that the person wanted to purchase the engine to put into a skyline.
But unless the car is already a GTR, there is still a lot to do fitting wise.
Edited by The Mafia
It was fine for months and months prior..
Just one of those 'street' things. Could have been poor fuel + the weather is a touch warm etc etc..
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
