just jap sell a fmic with the inlet and outlet on the same side. u just have to make ur own piping to mate with the stock pipes. i was considering this option myself. from memory it's around $200, no piping incl.
edit: heres the link http://www.skylinesaustralia.com/forums/in...c=82006&hl=
cheers man
i had a look at that one but looks like the pipes r on the wrong side, correct me if i'm wrong, but yeah prefer to have the pipes on same side, shld b heaps easier to install that way, does anyone know of any like that or does anyone have one on their car?
u say ur stock one goes alright hey, how much boost?
Edited by roy33
cheers man
you can turn the cooler around to have the pipes on the passenger side. they work both ways.
i'm only running 10psi, with zorst and pod.
These cheap coolers may be able to make "X" amount of power, but how many of those people, have taken there cheapo cooler off, wacked on a branded, more expensive, better built unit, to find that the inlet charge is now, even cooler, and even more power is able to be made?
A cheap cooler will do you for low power, but I wouldn't want to push one in high power.
hey guys
am thinkin about gettin a greddy FMIC so im just wondering what the difference is between
that and a cheaper version (justjap)....
i have been quoted a medium sized greddy FMIC (not sure on figures) piped and fitted for 1g
am i better off doin that or picking up a cheaper FMIC.
thanx
So, you would deem 480HP at the wheels ant 18psi as "low power" ?
They are a core
They do the same job
The piping might be cheaper, and the welds might not be as good but results speak louder than words
Same goes for the whole JDM exhaust vs Local made exhaust debate
as i sad above i had a "branded" cooler n no difference
monkey boy, get an FMIC dude, you dont know how crap the SMIC is till you get a real core that flows well and cooles the intake charge... seriously those smic cop heat soke in no time, your blower works overtime to pump air through it after a little open throttle you start loosing power in major ways not to mention nock and over fueling from various issues.
I had them and once going to a nice MUCH free'er flowing FMIC it really did the trick, not a single nock or backfire since and there ar !FAR! better FMIC's out htere than mine certainly.
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay ย
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.ย  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
    • Is this not just about people wrecking, and storing, multiple cars in their front yard? I now a tow truck driver that was contracted by the council to clean up housing commission front and rear yards in houses and unit car parks I'm all for working on, and doing maintenance on your car in your garage or driveway, but some people definitely take the pissย  There's one house locally to me that I walk past regularly where the front yard and driveway looks like a wreckers, multiple cars in various stages of being stripped, and the yard looks like all of fluids are basically dumped on the ground I may be wrong, but it seems that the initial reports, which I've seen nothing actually official about yet, may be getting taken out of context, like alot of the latest "the sky is falling" stuff found on the youtubes for clicks
    • have they? Link appreciated. I live in Casey. I can see both sides of the argument in this case. There's a lot of sketchy stuff going on. There needs to be a clear definition of what this is supposed to be IMO. I wager the intent was to be a broad sweeping brush against people who have 4 cars up on blocks on their front lawn, not someone who services their own car behind their own gate on a weekend bothering probably nobody. But it'd be hard to legislate the difference there.
    • Oh, the wheels were already off. I wouldn't normally take them off to clean them although it does make it easier with the ceramic, so I might take them off when reapplying. I don't drive much but now with the ceramic coat, when I do drive and they get dirty I can get most off with the pressure washer. I'll be switching to dirtier pads soon which was the motivation for the ceramic as I usually just clean them and sometimes use Autoglym wheel protector. Nah, f**k the barrels! Haha, I'll give them a quick scrub when they're off the car and a pressure wash, but even I draw the line with the barrels. Yes, dark coloured wheels allow you to get away with a lot! ย
ร—
ร—
