I was surprised by all my friends efforts.. and more so surprised that chicks ACTUALLY expect something! :huh: I thought Valentines day was just a novelty idea and it was a day where florists could increase sales by 90% - much like Guiness on St. Pats day.
Day spas, manicure/pedicure, flowers, chocolates, teddy bears.. every girl friend I spoke to received either one or all of the above mentioned. :)
The only thing that ever came to my mind was flowers and half a litre of pineapple juice. :)
Edited by S T A R 3 3
https://www.sau.com.au/forums/topic/156537-valentines-day/
  • Replies 40
Yeh well my missus is in Wagga and I tried to call about a thousand times and got nothing, so me is thinking I is in shit.
Quote STAR33: The only thing that ever came to my mind was flowers and half a litre of pineapple juice.
Thats gold man. Valentines day is meant to be something for both sides of the party. :)
https://www.sau.com.au/forums/topic/156537-valentines-day/#findComment-2909225
ahahaha
pathetic fact: a florist who was saying a large percentage of women buy flowers for themselves on valentines...
also, big congrats leigh
https://www.sau.com.au/forums/topic/156537-valentines-day/#findComment-2909433
I gave my girl an engagement ring 2 weeks ago so she got nothing for valentines day :O (oh yea everyone I am engaged ;))
OMG!!!!! congrats!!
so you bought an engagement ring.. well there goes the house deposit LOL
for valentines day I got a long stemmed rose and a card and a present will be bought this weekend....cos he was at a bucks last weekend and was too hungover to go to the shops and buy something :D
https://www.sau.com.au/forums/topic/156537-valentines-day/#findComment-2909665
i lashed out.
Got a $5 cute white bear that has a heart cushion attached that says "i love you" for the other half and got a very nice heart card in return,
Congrats Leigh!!! i went and picked up one of those shiny bits of metal with rocks in it last weekend... its somewhere very safe under lock and key.
Edited by low200
https://www.sau.com.au/forums/topic/156537-valentines-day/#findComment-2909723
OMG!!!!! congrats!!
No that's romance!!!! hehe!
https://www.sau.com.au/forums/topic/156537-valentines-day/#findComment-2909792
Like I said a couple of weeks ago Congrats Leigh wooh yeah good luck.
As for my day, I hate it. I am single every year for it and this time i didnt even get drunk, on a high note I did receive a happy valentines text. SO Romantic I know....
https://www.sau.com.au/forums/topic/156537-valentines-day/#findComment-2909974
Just caught this, Congrats Leigh.
Means there's hope for all you losers out there yet!!! If Leigh can do it....
Just kidding. I'll try to get my car happening for the wedding [gotta have some black there].
Ohh and as for Valentines...1. I'm too old, and 2. We just signed up for a $250,000 loan so roses etc are low priority.
https://www.sau.com.au/forums/topic/156537-valentines-day/#findComment-2911808
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
