rb26 instalition
Guest tigersharkr33
 Share
Guest tigersharkr33
hi,,,,to every one am new here.
i have skyline gtst with rb25det,am just wondering what to do!
my goal is to get around 600hp
i have rb26dett engine withe ecu and wiring,
if you are in my situation will you go for swap or modify the rb25det,and in case of swap how it can be done?????:)
i've just finished the conversion ur thinking of , and OMFG there are virtually nil swap over and wait till u get to the mangement section. but there i a very bright light at the end of the tunnel, if u got time a tatience then do it as a the amount of little odds bits that have to be done, it would cost a fortune or they would quickly bodge it.
I personally wouldn't bother with the RB26DETT Conversion.
I would mod the RB25 up to 300rwkw if that still wasn't enough then by then you need to start toughening up the internals so i would look at slapping a 3ltr bottom end and rebuilding that instead of the rb25.
i've just done the rb26 conversion but was running the autronic smc computer management system prior and found it quite easy.there was a slight mod to be done to the cross member,pulley to be pressed 5mm of the power steering pump to match 26 front pulley'and re-piping intercooling.radiator,throttle cabel,thrust bearing and gearbox all fit no problems.well worth the effort.i hope this helps.
Originally posted by -Joel-
GTS500 how does the Power delivery feel compared to the RB25DET's? i.e off boost, spool speed, response etc?
Drive a GTR and that will probably give a fairly good indication maybe ?
Cheers
Ken
True, however the GTR is a heavier car and also has different gearing. So it cannot be compared.
Different motor in the same car before and after is a good compare I would think.
when the rb25 came out it had 320hp with a small turbo the rb26 has a large turbo that is laggy till 4000rpm and then turns the tyres hard until the rev limiter kicks at 9000.its wild but blew third gear in the box on second test drive at 500hp and 19psi on bp ultimate.its the best thing i've done
Danny , thats comparing apples and oranges.
The RB25 was fairly stockish but that RB26 is a freakin animal.
Got the box back in yet ?
Cheers
Ken
2GU UP, depends on what you want the car for, if you drive it regulary just change the turbo and do teh usual stuff (cooler, exhaust etc) and you will make a easy 220rwkw. If you want more then you have to start decidng if it is worth changine the engine, but the costs will be much larger than doing a few simple mods.
I was fiddling around with a turbo calc last night and it appeard that what really hinders the RB30DET is the lack of rev's compared to a RB26. The RB26 will rev to 9000rpm where as the max the RB30DET can rev to is 7000rpm - 7500rpm due to harmonics.
Basically the RB26DET was better for all out power in the turbo calc.
However it isn't always about all out power.. No good boost coming in at 3/4 of the rev range for a street car.
 Share
    • Hurry while stocks last! 🤣 13% points redemption on this $6000 Mont Blanc "James Dean" ballpoint pen at Yodobashi Camera in Umeda, Osaka
    • It's not that at all....I just love the R chassis too much to keep racing it! Absolutely impossible to fix the damn thing if I bend it.... That last off I had (when I neglected to do what Kel said), we removed a gum tree with the side of the boot....needed a new rear quarter, boot lid, floor straighten, rear bar, front bar, both front guards, radiator, bov return and I still haven't got it back for a proper alignment to check it is actually straight again). There are just too many ways in tarmac rally to do significant damage to a car that you can't really get parts for.
    • Now I'd said earlier I'd checked the fuses, and per @Stick180's suggestion I checked them all again. The check was to use the multimeter in continuity mode on the top of each fuse where the little metal tabs are available for that purpose. All good....except that very "A/T Control" fuse was actually blown when I pulled it out and looked at it. Put it back in, tested it again, there is continuity to both sides even though the fuse is blown. I'll need someone smarter than me, but my suspicion is that I was getting a circuit through a power supply, through an incandescent globe somewhere, to earth, to the shorted wire and back to the other side of the fuse, making it look like the fuse was OK when it wasn't....please anyone that understands this f**kery explain it to me. Bottom line....that suspicious purple/white wire, in an undamaged factory loom, that goes to the the wrong place in the fuse box has a dead short to earth, confirmed from both ends.  How a single wire in a factory loom can be shorted, especially the best protected loom in the whole car (underneath the top of the dash) is going to keep me awake at night because surely whatever caused the damage has (or will) damaged other wires in that loom too. So, to finish this long and sad story....cut the purple/white wire where it exits the fuse box, ran a new wire from there to the ECU loom pin 31, fired it up and drove happily into the sunset. Only 4 days of head scratching and peering into footwells to get me there. Another collection of wire removed (in addition to the earlier photo) and a bunch of 10a fuses that gave their lives for the trouble shooting....thank you for their service.  And, since the car was in the shed I resealed the cam cover (first time I've ever had a new seal leak on an RB, but the Stagea is that kind of lucky), and I put in the boost doc cam splash plates to try and turn down the blow by a bit while I was there. Which, was all good because it also let me find the slow coolant leak, turns out it was from the turbo water supply which I nipped up again (the banjo bolt got new washers, and I tightened the hose end and hose to banjo fitting while I was there)
    • So, as it turns out, a new wire was the answer I went for, but getting there was not straightforward... Firstly, I'd been told before by shops that had worked on the car that it had some weird factory wiring, and I can now confirm that is true in at least a couple of places. For example....that very purple/white wire that provides IGN power to ECU pin 31.....I traced it out of the ECU loom into a connector high on the nav's A pillar under the dash, where it headed up and out of site across the dash, then back down at driver's A pillar. After trying about 8 different relays I found it coming into the back of the fuse box, and confirmed it was the same wire with a multimeter* (more to follow on that.... So, which fuse is the ECU IGN power connected to in my car?  Very top right, labelled IGN (good), 10A (good), Auto Trans Control (WTF?). It's not impossible it has been f**ked with before, but if so someone removed the pins from the back of the fuse box and moved it somewhere else, noting an AT control fuse would be functionally useless as the car was auto converted to manual long ago. It is not simply a wire cut and joined to the wrong place, both ends of the wire are the same colour just one is in the wrong location (you can see there is an IGN Engine Control fuse in the bottom row 4th from the right. Note, that is the fuse box sticker from my actual car, so either I have the wrong coin holder sticker, someone f**ked with it post factory, or factory sticker does not match the wiring.....whichever option it is just plain weird. Undermining the likelihood of someone having gone to that trouble to move a power feed when everything else in the loom had already been butchered....the fuse next to it IGN 7.5a ABS doesn't even have a wire running to it....so no idea where that fuse is on this car. All strange. But not the problem with my ECU power.
    • New tank clean paint and install complete 🤙
