rb26 instalition
i've just finished the conversion ur thinking of , and OMFG there are virtually nil swap over and wait till u get to the mangement section. but there i a very bright light at the end of the tunnel, if u got time a tatience then do it as a the amount of little odds bits that have to be done, it would cost a fortune or they would quickly bodge it.
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-320570
I personally wouldn't bother with the RB26DETT Conversion.
I would mod the RB25 up to 300rwkw if that still wasn't enough then by then you need to start toughening up the internals so i would look at slapping a 3ltr bottom end and rebuilding that instead of the rb25.
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-330304
i've just done the rb26 conversion but was running the autronic smc computer management system prior and found it quite easy.there was a slight mod to be done to the cross member,pulley to be pressed 5mm of the power steering pump to match 26 front pulley'and re-piping intercooling.radiator,throttle cabel,thrust bearing and gearbox all fit no problems.well worth the effort.i hope this helps.
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-330353
Originally posted by -Joel-
GTS500 how does the Power delivery feel compared to the RB25DET's? i.e off boost, spool speed, response etc?
Drive a GTR and that will probably give a fairly good indication maybe ?
Cheers
Ken
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-330368
when the rb25 came out it had 320hp with a small turbo the rb26 has a large turbo that is laggy till 4000rpm and then turns the tyres hard until the rev limiter kicks at 9000.its wild but blew third gear in the box on second test drive at 500hp and 19psi on bp ultimate.its the best thing i've done
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-330382
2GU UP, depends on what you want the car for, if you drive it regulary just change the turbo and do teh usual stuff (cooler, exhaust etc) and you will make a easy 220rwkw. If you want more then you have to start decidng if it is worth changine the engine, but the costs will be much larger than doing a few simple mods.
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-331029
I was fiddling around with a turbo calc last night and it appeard that what really hinders the RB30DET is the lack of rev's compared to a RB26. The RB26 will rev to 9000rpm where as the max the RB30DET can rev to is 7000rpm - 7500rpm due to harmonics.
Basically the RB26DET was better for all out power in the turbo calc.
However it isn't always about all out power.. No good boost coming in at 3/4 of the rev range for a street car.
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-331056
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
