Hey, the weather is up in the thirties today and its just that little bit too warm for my car to run without overheating with no fans, what I wanted to know was where can I find a constant power source in the engine bay when the key is turned to on. RB20DET R32.... Can't really be on accesories though as the fans will be crankin if Im just listening to music or what ever..
Cheers, Jayson
https://www.sau.com.au/forums/topic/156606-thermo-connection/
Cheers, Jayson
Jayson,
The factory fan relay has power when the key is in the "ON" position. You can simply bridge the terminals for the factory temp switch to activate the factory fan. There is a connector on the drivers side of the radiator which you could unplug and bridge the 2 wires. If you want to activate additional fans you can use these wires to trigger another relay which is dedicated to the other fans.
Hope this helps.
Cheers
