When Will Nissan Cube Import Be Available?
  • Replies 508
I'm an import broker who likes cars and doing applications :)
My application came out at somewhere around 35 pages in total, so if they come back asking for more information, I'd be extremely surprised.
Iron Chef,
would you have happened to put either the Be-Go or Mitusbishi i on the list?
I'm an import broker who likes cars and doing applications :banana:
I didn't do either of them - the Be-Go I can't see much point in personally. The i is an excellent choice for a SEVS car, but I would've waited until it's 18 months were up and done it as used. Might go off and check the release dates now actually.
I've got two other applications in apart from the Cube at the moment, but they're hush hush lol
18 months are up already, Jan '06 release!
No reason to keep SEVS listings secret, everyone just plays follow the leader in this industry anyways.
We're working on the Tata Nano and Xenon at the moment....haha....or maybe that's just disinformation.
Any of the newer Daihatsu's are eligible as they are not imported officially anymore, so since "Make of vehicle not currently supplied in MA Category to the Australian market in Full Volume." it is open slather.
Hence why I'm working feverishly on all Cadillac models before October :P
Cadillac are worth doing these days and are a car people always ask for, on the Cube it will be more then worth while doing as we are already sourcing a 2002 and 2005 (emissions) as per Y34 so we hope it is approved.
Schedule was updated this morning and nothing either way on the Cube, some one put in for SUBARU FORESTER S2 and strangely enough it was rejected.
See above - I can't believe someone tried to apply for it under SEVS...
I dont get it. The S2 is the model i have maybe? What does the S2 look like and why was that so strange?
Is it the SG9 or an earlier model..?
    • I was actually going to try and dig out a datalog with turbine speed and EMAP haha
    • Wait until @Lithium posts a compressor map and tries to explain what's going on. There is a strong possibility that the OP lives in a digital world and is not comfortable with analogue machines. A turbo is just about as analogue as it gets, with plenty of non-linear behaviours added in on top. Most of us who think we know how they work are actually only getting by on 2nd and 3rd order mental models that abstract away from the actual physics and bring it back to the sort of kindergarten level concepts we can hold in our heads. This is important when you need to hold 10 such concepts in your head at the same time. You need to reduce the complexity of the individual concepts to allow them to be simultaneously held and manipulated. Too much complexity in the base models makes it very difficult to make them work with each other mentally.
    • It could be. It might not be. It is impossible to know without context by asking the owner or the tuner on the day and knowing what they were doing/not doing/attempting to do. You said earlier this is hard to understand because to your mind, a turbo is at full speed when it hits its spike. This is not true. The turbos actual speed is defined by how much air is being forced through it via the exhaust, unless you control it. The spike you are seeing at ~whatever RPM it 'spools' at, is where boost control is starting. If there were no boost control the turbo absolutely would be spinning much faster at 7000rpm than 3000rpm, every single time, on every single engine. Boost control keeps the boost controlled within the limits you ideally want. If it were uncontrolled you would have two scenarios 1) You have a turbo that hits peak RPM and CFM (not boost) at the redline of the engine. This would work, but most people want more boost earlier. 2) You have a turbo that hits peak RPM well before the redline of the engine (say, 3500), and you explode the turbo by redlining the engine. (say, 7000rpm). If you don't want exploding things, or lag, you design a turbo system to come on when you want the boost to be useful, and then not overspin itself into oblivion by using some form of boost control, to control the boost pressure accordingly.
    • Yep. >10 posts required. Prank can relax that for individuals when required.
    • @PranK is there a restriction on posting pics based on post count?
