  • Replies 508
you guys in Oz must make a bucket load of money ..... i keep asking myself why am i in japan......
living and working in japan has lots of perks but sadly from what I've seen over the years big bux is not one of them :dry: used to be good when the AUD was only worth 50yen but these days it's a different story. Of all the ex-pats I know working in japan as car exporters, parts exporters, teachers, etc the only ones making really serious dough do regular type $$ careers like investment banking, analysts, consultants etc.
BUT there is a lot of other good things about being there and you know it!! :)
from his site:
http://www.tgvi.com.au/vehicles/cube/
The Nissan Cube is a popular vehicle overseas in America and Japan. Released in Japan in 2002, the Cube has become somewhat of an icon. With its many stylish options and variations available, everything from body kits, exhausts, rims, and fog lamps. Both 2nd row and 3rd row seats(7 seat option) fold flat to allow even the biggest items to fit in the back.
We are able to provide compliance for the following variants:
Make: Nissan
Model: Cube
Variants: Cube (5 Seat)
Cube³ (7 Seat)
Year Range: 10/2002 - Current
Doors: 5 Door
Engine: CR14-DE 1.4L
HR15-DE 1.5L - 7 Seat Only
Transmission: 1.4L - 4 Speed Auto
1.5L - CVT
Drive: Rear Wheel Drive Only
Further Info: Model/VIN Codes
BZ11 1.4L 2WD 5Seat Until 12/05
YZ11 1.5L 2WD 5Seat Until 12/05
BGZ11 1.4L 2WD 7Seat Until 12/05
YGZ11 1.5L 2WD 7Seat Until 12/08
Can not plate the following
BNZ11 1.4L 4WD 5 SEAT
YGNZ11 1.5L 4WD 7 SEAT
Click here for contact us regarding Nissan Cube compliance!
without getting into a shit fight :D I took your post as literal. I did not see a inside joke there. there are 4wd cubes running around. I have done a couple.
Gearing supplies all of the ADR gear for these things as it is. you and I both know what needs doing on them and what DOES NOT get done 90% of the time.
if you are going to joke about things make it a bit more obvious :)
I'd love RWD to be honest, I'd be more inclined to crank the boost when the supercharger kit is fitted haha - either way I think a FMIC is in order...
http://www.skylinesaustralia.com/forums/Guys-t313709.html
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
