When Will Nissan Cube Import Be Available?
for anyone that has a cube. i just got a recall in the mail from nissan yesterday. its something to do with one of the fuses/relays in the engine bay. ill have a read later and scan it and put it up. then you guys can get yours all sorted.
  • Replies 508
japan Nissan recalls chassis range:for Z11 Cube
BZ11-141666 TO BZ11-312231
BNZ11-027192 TO BNZ11-102034
YZ11-000001 TO BZ11-013186
BGZ11-621890 TO 701061
YGZ11-100001 TO 106253
YGNZ11-001001 TO 002010
Nissan japan says
"Nonconforming structure in the state finds a reference in power relays for engine control unit or performance situations and their causes, improper method of manufacturing a diode that is built into the relay, it may lead to a poor conductivity. Therefore, continued use of the box, it may stall out while driving and poor engine starting.
Replace the contents of safe products to improve the relay."
NOTE:
not all cars are affected & chassis needs to be checked.
Not a real concern as is VERY unlikely to cause any problems on our cars
no probs. it was easier for me to rip and dump it. there was another one for the earlier cars as well dated 2005. didnt bother with that one.
david was poking around looking on aonther site when I realised what he was doing and I sent the nissan one across.
the pdf is a direct rip of that site translated to english.
The cube is one of those cars that is so ugly its just damn coool.
Would love to have one as a daily runaround.
me too
For anyone interested, I now have a full set of factory overfenders and the factory retro stripe kit for the bonnet and sideskirts, and am planning to reproduce both to make them as a kit with Rota RBs (Watanabe copies) to make the plain ones look a bit purdy.
The factory stickers only come in a metallic black colour, and the most of the Neo Classic Cubes all seem to be police car blue, so it'll be fun to see what they look like.
you never did this right? watanabe and overfenders sounds perfect.
yeh it has turned out pretty nice.
and still have good clearance wherever i go. no scraping or thudding. its been a long time since i havent just put coilovers in. springs are easy.
no scraping or thudding with two in the car. any more and it scrapes like buggery. im in trouble already for this. haha
got to roll the rear fenders or go back to standard springs.
chef - what did the do with the rear bar where it meets the fender on yours?
They re-welded the plastic to bring it out further (hence the expense!), then attacked the seam where the panels join with an angle grinder (I had to go back because it was scraping hard enough to pull the rear bar down),...to help keep the two panels together they ended up using some really strong double sided tape, which has worked a treat.
Have a close look at where it is scraping because it may actually be hitting that seam rather than the lip of the guard.
wow, that sounds costly....
its definitely the guard. theres lots of rubber :)
i dont think its hitting the rear bar tho.... just the front side of the guard
well....turns out I don't need to flares, mine came with them.
this is the new car.
I need suggestions on a 3 digit/letter plate....because HGE 80X gives the wrong impression about my wife. Need another suggestion HGE xxx for this car to join HGE 32R, HGE 70W and HGE 10L
That's is such a cool little car,,,I love it. If we ever need a daily the cube will be it.
How does HGE-LOV sound,,,or HGE-14C,,,or HGE-ley.
Cheers
Neil.
    • Sadly, it won't happen. The AC controls in our cars are essentially on-off. Whereas the AC in new stuff is more a case of variable displacement compressors giving infinitely variable output.
    • I don't think anyone did. But it still made me consider. For me personally it wasn't clear whether the AC experience in my car was shit because it is an old system, or because it wasn't maintained. Looks like it may have just been the latter. I see some more modern setup being sold as an upgrade and I wonder whether it would make it drive like AC in a modern car. Where you don't really hear it or notice it. But maybe that's asking for too much as well.   Haha, stick it in a Nissan Cube and you end up with a driveable fridge I'm not doubting your experience. Just thought it was interesting to hear the AC technician's thoughts on it.
    • Guess I should be hunting down one of these big ol ford units then for max flow ....  I've had fresh gas in mine and it was never as cold as it is now . The compressor could have been trash though, like I said I am one example with a bunch of unknowns.
    • I don't know if anyone was seriously suggesting a retrofit of an Echo compressor in place of a more-or-less working original comp. You'd have to change the hoses at the bare minimum to do so, and that will definitely add significant cost. I had to get my hoses modded when I did the engine transplant and chose to use the Neo's AC over the even older R32 comp. That was startlingly more expensive than expected for what looks like a simple welding job, and a massive pain in the arse when it turned to have a pinhole leak in the weld too. The Frenchie's kit is for people who have next to nothing of the original system or have more than that but some of it is a bit shit and better off thrown away than salvaged. If you've got 90% of the system, you just patch it up. Mine is currently degassed because it apparently has a big leak somewhere. If I find it is the compressor, I will be looking to take my spare comp to a shop to assess and/or recondition, rather than contemplating a retrofit to anything off-brand.
    • I went and got the aircon regassed in the Stagea today and asked the guy about the upgrade to the Toyota Echo compressor. He was saying it is likely not going to be as good. It is newer but smaller and not going to pump as strongly. And it would be better to try and get a new OEM compressor. He was saying that the improvements people are seeing may be more likely due to regassing the system. I thought it was interesting to hear. Going by the sticker the system in my car was last checked in 2015. Gas was at 50% which is apparently beyond terrible. Under 80% is where efficiency already falls apart. Anyways, with fresh gas the AC is now bloody freezing. I think it may be working a bit less hard as well. I need to drive it a bit more to try it properly. Previously on hill starts it would utterly bog down the car. I'm hoping this is a bit better now. The frenchies kit looks great, but $1400 for the compressor upgrade alone makes it a bit of commitment. Very much so compared to a $150 regas.
