I did tell u something constructive...you really won't be able to get much out of the mines ecu if you can't tune it to suit your car...how about you ask proper questions before you have a go at me?
Good size for what? 300hp? 500hp?
What do you already have? and what do u mean by parts needed? parts for the swap alone? or parts to support the new turbo? and then...it also depends on what turbo you want to get...which will determine what parts you need...thats why i said search first...how do you expect people to help if you aren't clear?!
Edited by limpus
Ok...in terms of support mods you seem to be on the right path...you will need some sort of programmable engine management...as for the turbo to get...look at the rb20 turbo upgrade thread...you will be able to see how others are doing and follow the same path...
To4e is way too big for any practicality in an rb20...rb25 hiflow is my choice hands down because it involves not much modification to fit, not ridiculously laggy, it and its good for at least 200rwkw with supporting mods.
If you dont have a full exhuast system get one of those first.
Raz
An apexi avcr is NOT engine management...its a boost controller...and as i mentioned...jap tuned ecus are usually useless here in australia because they are tuned for very rich air fuel ratios and higher octane fuel...if they can be retuned then it might work...but in the end it'll just be like a remapped ecu...in the end...you have 3 simple options for engine management...piggyback(safc, emanage and the like)...remap(dr drift remap) or stand alone(power fc or similar)...i'm guessing your car has a mines tuned rom in it since you're so keen on finding out about it...speak to your local tuners to see if it can be retuned...if not bin the thing...
i have searched mate. i need answers. So if you have nothing constructive to say then piss off!!
that post was probably the most informative and truthful post in this thread. And with a reply like this one quoted, I hope you get flamed to ashes.
A mines ECU IS USELESS unless you have someone to tune it. If you leave it how it is it will be exactly as it states - a mine. Your engine will go kaboom.
and AVCR is not engine management, its a boost controller.
How hard?
There is some quite useful info here:
http://www.skylinesaustralia.com/forums/in...howtopic=103095
Which is at the top of the PI page.
Otherwise search using keywords like Slide, GCG*, 2530*, 2871*, Discopotato, MTQ*, highflow, etc.
Make some effort to search and see/read what others have achieved/done, before telling someone where to get off.
The whole thing isn't about instant gratification. If you want to modify then you need to know exactly what you want out of your car, and what use you want to put it to. That will ultimately dictate what works best for you. :)
And here's a thread that was active in only the past few days about remapping:
http://www.skylinesaustralia.com/forums/in...howtopic=143835
If you want to know about stand alone replacement ECU, then try searching PFC*, Apexi, Microtech, Datalogit.
Again, it's only down to your budget and intended outcome. You could try Googling Adaptronic too.
None of this is hard, just a bit time consuming to build your own understanding.
Edited by Dale FZ1
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
