Hi forum.. :wave:
I just joined up to get extra informaiton about skylines as i want to buy a skyline 96 or 97 model. r33 i guess
I just have to questions:
Why did nissan stop its skyline models after 1999?? than it made a another model in 2003 than it stopped again. i am not sure plz correct me if i am wrong.
If models are stopped that means parts would be hard to get in two years time?
is it easy to get parts for skylines in Queensland??
Only thing worries me is the parts for skylines, if u can't get it straight away it will sit in workshop for ages.
Please reply back and give me some advice.
Cheers
Ranjha :sorcerer:
https://www.sau.com.au/forums/topic/156689-skyline-information-needed/
If you have just joined, start searching you will find that you seek here. if nothing then ask questions The ease of getting parts is limited by time and money. Time to search money to buy.
/quote
/quote
That is irrelevant question just because they stop making the model doesnt mean the parts stop, companies alike are still making parts suitable for r33's and r32s easy to get parts as well, check out those sites that have these parts in store to see for yourself. at the end of the day money is your limiting factor, if you cannot afford do not get thats simple.
skylines are money pits if you want them to be money pits. GTR's are more expensive for a reason, check out the differences between gtr's and gtst's you shall find these in the search function of this forum.
holden parts? more to the fact that holden use some nissan parts, parts and numbers will and can be accessible via the search function.
Cheers
Adam
Skylines are not expensive to maintain if you purchase a good one at the start, get a trusted mechanic to go over it and do all the coresponding enging checks (eg, leakdown test, compression test ect...) as engine rebuilds are about $5k for a reasonable build. I got mine checked and it has run like a dream for 2 years now, the only time it was off the road was my fault :) . Also if you are chasing second hand parts there are lots of them going in the for sale section on SAU there is also a wanted section so you can post there and get parts that way. If you would like any more information give me a PM and I will point you in the right direction, but try a search first as just about everything you could need is on here somewhere.
Chris
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
