  • Replies 138
Ok guys, just to tally up to date, so far we have:
R Dirty 3 (Thats me)
God Thrilla and Mrs Thrilla
Dan the Man
Pulp and Girlfriend
Tigeryas (Date pending) CONFIRMED.
Mr Keets
Gts-t Vspec
Nizmo
Chainfire PLUS 1.
342Four UNCOMMITED TEAM MEMBER!!! :D
Sam Kids are allowed, so you can come :P
StageaGirl and Jnr
Mitchy
R34Maniac and Chaffeur (he has to drive the beamer :P )
Topaz
19 total 27-Feb-07
So far thats 19. So far so good. Would be good to see a few more as groups play in lots of 4.
Its a cheap, good fun afternoon. We are only playing 9 holes so it wont take up your whole day. You will still have time to mow the lawn, paint the gutters or what ever other fun activities you can think of.
Keep the numbers coming :O Its a good chance to meet others that you may not have met. Out of all these people i think i have met maybe 3 or 4 lol
Regards
Brad
well, i'll let you know on the monday then, i want to keep it as late as possible so as not to possibly interfere with anything else that might come up
and no its not an excuse - its just that we have a large extended family and knowing my luck something will fall on that day
Have you always had this fear of commitment? lol
p.s. my wife saw my post in your signature. That took some explaining lol
Hey guys. The date is booked! Its game on.
Ben, yes i would think it fine to bring a mate along. The more the merrier.
Enjoi, if you are interested, let me know fairly soon.
If i can have confirmed numbers by this time next week, that would be great.
Currently have a booking for 20 people. If more want to play, that should be ok but ill need notice to up the booking. Getting there on the day and adding people is going to be an issue!!
The prices (Group booking price)
Adult $10.20ea
Child $8.50ea
Group is booked for 2pm tee off. It is stated that we get there between 1.30pm and 1.45pm. That will give us enough time to organise what groups we are playing in (groups of 4 or 5), and then they will start calling groups through at 2 sharp, at 10 minute intervals. Make sense?
Any questions? Have i left anything out.
Regards
Brad
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
