I have a dva 5210 alpine head unit,
theres nothing in the instruction manual.
I cant get anything outta the subs, the light is on the amp wondering if anyone can help. and does anyone know how to change the clock in these things the manual gives you nothing.
https://www.sau.com.au/forums/topic/156741-alpine-problem/
i dont know if this helps but when i wired my alpine amp up to my clarion head unit i had no volume control turns out it was cos i put the sub pre out to the wrong one ,there was one assigned to the subwoofer and i put it into a normal speaker one. silly me :happy:
https://www.sau.com.au/forums/topic/156741-alpine-problem/#findComment-2913191
Have you recently installed this unit and can't get it to work, or did it just stop working one day?
I have a problem with my Alpine (due to the original owner using the normal RCA's instead of the specific subwoofer RCA's). When I reset my Alpine head unit, it automatically turns the 'Sub' light on the head unit, which cancels sub frequencies to the subwoofer.
It's probably not ur problem, but a possibility.
Fixxxer
https://www.sau.com.au/forums/topic/156741-alpine-problem/#findComment-2914453
Just whenever I disconnect my car battery (and lose all settings on the headunit) it always comes back with the 'Sub' light showing on the headunit. I just go into the function/setup of the headunit, and turn the 'Sub' from 'ON' to 'OFF'. By turning it to 'OFF' the sub frequencies are not cancelled out.
Fixxxer
https://www.sau.com.au/forums/topic/156741-alpine-problem/#findComment-2915400
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
