Its finally in ....my brand new! r34 turbo is on my car.
And it only took me two whole days!! I was expecting it to take
3 hours...........
Yes everything bolts right up except the r32 outlet pipe is too small for the r34 turbo outlet (this would have come with it if it was used!), but after picking up a vg30 outlet and some piping
from the wreckers was all sorted out :)
Its a great upgrade, the car now doesnt drop off boost like it did before at just below 6000, now holds boost all the way to the redline.
Its got slightly more lag, maybe 500 rpm later, but then it goes much much harder :burnout:
And im only at 9psi (playing safe for now), so there heaps more to go
Now just need an intercooler and a remap....
https://www.sau.com.au/forums/topic/15676-yay-r34-turbo-in-r32/
With sourcing the turbo...i was lucky i got it of a fellow skyline owner who brought it back from japan and didnt need it anymore
i paid $850 :)
I was just going to get a used r33 turbo until i saw this one for sale...i think there isnt too much difference between r33 and r34 turbos maybe someone else will know the turbo part numbers are;
rb20 - 16V
r33 rb25 - 45V4
r34 rb25 - 45V1
Reason i didnt go for bigger turbo, is dont want to get into bigger injectors, aftermarket computer $$$ etc etc and didnt want lag.
Advice:
- Stock r34 wastegate actuator boost setting is 6-7 psi, so you need a boost controller or you will be disappointed
- r33/r34 turbos get actuator signal from manifold (not compressor
snail as in r32), i just teed of the carbon canister line as this was
close to my boost controller
- use a hoist if you can, so much easier to get to oil and water drain lines
Thats it nissky.. :)
I've had a VG30BB turbo on my RB20DET.
Don't do it... The standard turbo hits much harder and a lot quicker for the street.
I was making full boost with full throttle in 3rd gear loading it up at around 3700-4000rpm. In second gear just powering on as you do it would hit full boost at 4100rpm.
First gear felt like it was basically a non-turbo car.
Up top it didn't even really pull that much harder than the standard turbo and due to the VG30BB's age it still dropped off boost up top.
Seriously the VG30BB Turbo I was very dissapointed.
Depends how you drive.
If you use it for the track then sure don't go over 12-13psi but if you are only using it for the street and only having short bursts not constant hammering it will be ok.
For example my standard R32 Turbo.. I've been running 16psi through it for over a year now. The car has done 60,000km's since I bought it.
Personally A lot of people speak from what they have heard, but I have only ever heard of a R34 Turbo dying on a RB25 running 1 bar of boost and doing several laps around a track flat stick.
Speed kills a turbo as quick as heat does however PSI doesn't kill it as quick.
Hi Guys, I have seen only 2 X R34 GTT turbos, both had ceramic turbines and plastic compressor wheels. They were not made by Garrett either, they were the same design (so Nissan must own that) but made by someone else, IHI maybe.
Turbo bits were interchangeable with R33 GTST ones and GCG did the usual hi flow and the result was the same.
Hope that adds to the knowledge base.
sydney kid when ya say the result was the same.
SAME as what ???
and joel yer right on when ya run 1 bar for street it doesnt damage anything i do it too and my liner doesnt even break a sweat and thats with stock cooler dude from advan (silver 32 ) runs 1.2bar with fmic
Hey Doc,
When you say you were leaning out, were you still running
the stock fuel pump??
Mine was leaning out on the stock pump with stock turbo, i upgraded to gtr pump last year so i should be ok.
I think its time to put my dodgy fuel pressure gauge on again...:uh-huh:
  • 4 weeks later...
hey just reading this post and its interesting........ what are the increases a rb25 series II turbo will give on a rb20det @ same psi (kw@wheels) and also i was thinking of getting a 3" dump pipe as well...... the rest of my exaust is 3" (cept dump) so with the rb25 turbo and 3" dump what would my kw@wheels increase by on the same boost? also would driveability be increased?
It will increase lag slightly so you will have less bottom end. If you have an Auto that is bad.. :cool: If your running a manual then all is ok.
A dump pipe will make the car feel like its got more torque when making small amounts of boost i.e driving normally.
Generally a R33+ Turbo at the same boost pressure as a R32 turbo should make an extra 15rwkw.
How laggy will a hks 2530 be? And how are you defining lag? What i thought was lag was, where it would normally take boost, and you mash your foot... how long it takes to pick up boost, not at what rpm it starts to make boost? Could be wrong tho.. Im also looking for a new turbo for an RB20. Would the 2530 be a much better choice then say a R33 hi flowed? They would have around about the same price, what power outputs with aftermarket ecu, a good front mount + bigger injectors/fuel pump and and good 3inch exhaust and seperate dump pipe? I know thats a heap of questions but im just trying to work out a budget and whats worth spending money on :(. Im aiming for 220-240rwkw. With that power in a 1200kg car what times would i get aswell? :D
