Here is a list that was compiled by some R31 club members.
I can't guarantee that all of the following will fit, but these are what was on the list.
Take into account that all the front wheel drive cars will have a slightly different offset.
WHEEL OFFSET
r32 gts non turbo (4 stud)
r33 gts non turbo (4 stud)
r31 skyline
pintara
most pulsars
maxima's
n/a 300ZX Z31 (80's type)
180sx
hr31
magna (80's models)
SIGMA'S
bluebird TRX
Early Datsun roadster
Datsun 240sx 89
Datsun 200sx - early
Suzuki swift
saab 900
toyota cressida 80 -91
toyota celica rwd
toyota carolla rwd
Toyota supra - 4 stud ones
Tercel 79-82
Ford capri
ford festiva
Ford falcons (4 stud ones)
ford maverick (4 stud ones)
all hyundai's
mazda 323 86-89
mazda 626 88- 91
some rx7's
mitsubishi eagle ?
gallant 83-97
mirage 88-92
late 80's preludes
accords
toyota liteace
The stud pattern is 4 studs at 114.3mm or 4-1/2
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
