RedDrifter Posted February 17, 2007 Share Posted February 17, 2007 (edited) Ok I have a set of 6 RX7 550cc Injectors. These are a great upgrade fr the RB20DET and they are high Impedance so no resistors or GTR resistor pack needed. I pulled these out of my R32 today as I decided they were way over kill and GTR injectors seemed a better option for my power levels. They need new seals however I do have the plugs with them. Part number of the injectors are 195500-2020. Asking $400 but I am negotiable on reasonable offers. Payment via direct deposit preferred. Pics will be added soon. Edited February 17, 2007 by RedDrifter Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/ Share on other sites More sharing options...
RB20JT Posted February 18, 2007 Share Posted February 18, 2007 can you PM me how long you have had the injectors and power you were running with them and the duty cycle at that power. as i have an r32 and im intersted in these injectors Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2914058 Share on other sites More sharing options...
RedDrifter Posted February 20, 2007 Author Share Posted February 20, 2007 can you PM me how long you have had the injectors and power you were running with them and the duty cycle at that power. as i have an r32 and im intersted in these injectors I made 300rwhp and the injectors were running about 60% duty cycle @ 11:1 afr from memory. 550cc Injectors are good for about 550 bhp on a 6 cylinder. Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2920285 Share on other sites More sharing options...
cuong nguyen Posted February 20, 2007 Share Posted February 20, 2007 have u had them cleaned n flow tested? do these straight fit into the rb20? Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2920738 Share on other sites More sharing options...
RedDrifter Posted February 20, 2007 Author Share Posted February 20, 2007 have u had them cleaned n flow tested? do these straight fit into the rb20? I had them cleaned and flowed before I installed them in my Rb20 3 years ago. Though they haven't been cleaned since I removed them. They were working fine when I had them in in just they were a little to big for my application. They are a straight swap just require you to replace the injector plugs on the loom which I am throwing in for nothing. Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2921293 Share on other sites More sharing options...
RedDrifter Posted February 20, 2007 Author Share Posted February 20, 2007 have u had them cleaned n flow tested? do these straight fit into the rb20? I had them cleaned and flowed before I installed them in my Rb20 3 years ago. Though they haven't been cleaned since I removed them. They were working fine when I had them in in just they were a little to big for my application. They are a straight swap just require you to replace the injector plugs on the loom which I am throwing in for nothing. Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2921294 Share on other sites More sharing options...
RedDrifter Posted February 21, 2007 Author Share Posted February 21, 2007 Price drop $350. Guys these come with the plugs as well. Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2923167 Share on other sites More sharing options...
TurboX Posted February 21, 2007 Share Posted February 21, 2007 Dont forget you can mod the inj. socket and use the orig plugs with out having to fit new ones. Easier to just cut away a bit of plastic in the 550cc socket - Dont forget to clean them before fitting as well to save heartache as they can gum up if sitting around not used for a month or so. This is a super deal - I paid $120 each cleaned and tested a fair while ago. More here Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2923223 Share on other sites More sharing options...
jeffers1987 Posted February 21, 2007 Share Posted February 21, 2007 how much does it cost for new seals. very interested in these, waiting on some money to come from government. will get to u asap when i get the dosh Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2923245 Share on other sites More sharing options...
RB20JT Posted February 23, 2007 Share Posted February 23, 2007 do they require new seals??? Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2929483 Share on other sites More sharing options...
CEF11E Posted February 23, 2007 Share Posted February 23, 2007 seals are like $1 each Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2929859 Share on other sites More sharing options...
RedDrifter Posted February 23, 2007 Author Share Posted February 23, 2007 Need new seals and yeah they are cheap as. Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2929877 Share on other sites More sharing options...
RedDrifter Posted February 24, 2007 Author Share Posted February 24, 2007 Price drop $300. Not going any lower though. These are a good buy people. It cost me alot more than this when I bought them. Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2932317 Share on other sites More sharing options...
Cubes Posted February 25, 2007 Share Posted February 25, 2007 Have you ever had them flow tested? How long ago? Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2933429 Share on other sites More sharing options...
RedDrifter Posted February 25, 2007 Author Share Posted February 25, 2007 Have you ever had them flow tested? How long ago? Yeah about 3 years ago. Just before I put them in my car. They all flowed equally within 1% of each other. From memory they flowed just over 550cc each. These work well with a power fc and I no doubt would be a good setup on the RB30 Cubes . Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2933879 Share on other sites More sharing options...
NV N01 Posted February 25, 2007 Share Posted February 25, 2007 Would you do $300 delivered? I'm in Brisbane and am very interested.. Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2934002 Share on other sites More sharing options...
NV N01 Posted February 26, 2007 Share Posted February 26, 2007 PM Replied to.. Consider them SOLD Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2937212 Share on other sites More sharing options...
NV N01 Posted March 1, 2007 Share Posted March 1, 2007 Just transfered the money then Let me know when you send them off.. Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2945605 Share on other sites More sharing options...
RedDrifter Posted March 3, 2007 Author Share Posted March 3, 2007 Injectors Sold. NV NO1 : PM sent last night. Link to comment https://www.sau.com.au/forums/topic/156770-6-rx7-550cc-injectors/#findComment-2949948 Share on other sites More sharing options...
