Hey guys
I feel like a retard, but I was trying to use an easy out today. This is the first time i've ever done it.
But I broke the easy out! The broken bit of bolt turned a bit, so I knew it wasn't seized anymore. Then boom. It snapped and the bit got stuck inside!
I managed to drill again, but the hole sort of went to the side because the easyout pushed the drill bit sideways.
I tried a new easyout, but it still didn't work.
what can I do?
https://www.sau.com.au/forums/topic/156783-easyout/
if it's started to come out you can drill a couple of small holes either side of the easy out and use a pair of cir clip pliers to unscrew it the rest of the way.
If no good, call a professional as you have buckleys of drilling through the easy out with a regular drill bit.
https://www.sau.com.au/forums/topic/156783-easyout/#findComment-2913157
I have managed to smash the broken piece of ezyout with a centre punch, they are quite brittle as you found out the hard way, it wont work now because the hole is off centre and the twist u put on the ezyout should be a push at the hole in the unscrew direction.
https://www.sau.com.au/forums/topic/156783-easyout/#findComment-2913837
ok, I'm a spaz. I just dug myself deeper into a hole
Before I read your reply, I used another esy out in that side hole, and as you said, it broke again since the torque wasn't being applied to turn the bolt.
Luckily it's only just the turbo heatshield bracket. People normally chuck that out and don't use it, but I wanna cover the turbo. so if anyone's got one in sydney, i'll take it
https://www.sau.com.au/forums/topic/156783-easyout/#findComment-2913856
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
    • How hard are you tracking it? I have 378 in front and 355 in the back with decent pads and my brakes were spongy after a decent session with lots of braking. It was a short track though but got up to around 190-200 max. be keen to hear. Mind you, I havent flushed my fluid so thats probably part of reason.
    • Awesome thanks for the reply Man! I already plugged up the back just cause I can’t take a chance on it leaking on me again haha. But i will fab a catch can with 2x for the cam covers and a lower one for the sump vent.    Now as this will drain back as well , Is there any concern I should have of the oil being drained back. I don’t run e85 or anything .   2nd question is, from the picture does it seem that my sump fitting is above oil level? Silly question but I rather have someone’s experienced opinion lol
    • How good is it though when you can run the AC without the engine running to cool the car off before you get in it during summer? God I'll miss a bunch of the EV features when it leaves on Monday
    • I hear you were headed for a track day yesterday... Thread clearly needs updates
