hi to all!
well i am an apprentice sheet metal worker im 23 and doing an adult apprenticeship i have been mucking about with metal since i was about 14...here are some of my projects i am making and planning to make
ok first up i made this air filter adapter out of 1.6mm thickness stainless steel sheet and 75 mm 3" tube...
preperation is the key to tig welding something of this nature can bu "fused " together this is when you apply heat to a concentrated area and the join simply melts together you move on at a steady rate keeping an eye on the moulten pool this is fusing....to have a successful fuse you must have the two edges of material clean and as close as possible if you you try to fuse 2 peices with a small gap it will simply burn away leaving a hole or even bigger gap to fill! and it suxs been down that road.. this is an un pollished part at the moment stainless can be pollished to a number 4 finish using scotch brite scouring pad...this is food grade finish! not that i will be eating off this..high pollishing is possible with the right buff wheels..i found this finish is enuf.
ok second here is the first oil catch can i made ...it was originally made for my buggy (turbo suburu single seat buggy full custom) but i am using it to mock up the hose arrangement as my car is off the road turbo is at Slides....
ok once again stainless steel used 4 inch tube, 2 end caps, small pipe to fit air filter,
i will add step by step pictures when available monday or tuesday...
but basically this was all fused together bar the inlet pipes where the metal was not touching some filler rod was used (filler rod is stainless steel in a rod form usually 1.5 to 2mm thick sizes vary) you start by "tacking' the end cap on place a tack every 1 cm or so to hold in place securely then lightly dolly /tap with a small hammer to close the gap around the join no gap it what you want.. then proceed to fuse it on you may want to do about a 4 cm long strip then using a wet rag cool the metal by placing the rag directly on it this will prevent the metal from warping due to excessive heat. take your time it will come out better if you do it right! ok thats it for now till pictures arrive
number 3 here is a heat shield i made in around thirty minutes very simple only tool used was grinder tig a press and gilotene
ok i now the press and the gilotene are out of the question for most..but it all can be done with a hammer tig welder gringer and thats about it. same applies for fusing this as stated above preperation is the key!!
if you have the tig to hot or incorrectly sharpened it whill burn unevenly and you want nice even penetration and not to much a that!
i will be adding more and more as i go am currently making an alloy air box here is some other pics just of what is possible with a bit of time and patience!
hope this helps any question just pm me if this isnt detailed enuf let me know can get right down to the nitty gritty!
cheers
soon to be alloy air box..
bit of time turned this
into this: nuthing to special but an improvement
https://www.sau.com.au/forums/topic/156809-my-fabrication-tips-and-projects/
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
    • No, I don't remember the exact reasoning (was 20 years ago!) but the cops didn't end up supplying it to us either. Actually my mother went through a similar thing recently where she was hit when stationary, flustered and didn't get address (she got plate details, name, phone and insurance company, but not address). Person who hit her blocked her number and their insurance company (naturally) would not provide any details. Her insurance company also required her to pay the at fault premium because she did not have the address, cops did not help as it is a minor civil matter (they said their only course was if the other driver had left the scene of the accident without providing any details). She only ended up getting that refunded because they happened to be insured with Suncorp and she was with APIA so same company owners. For some reason the address is critical in insurance companies recovering money from the at fault party
    • If you're driving something like an R32 through to R34, no chance of meeting Euro4. Euro4 came out in 2006, and car manufacturers back then were complaining how hard it would be to meet those regulations. Not a chance a vehicle 10 years earlier is going to be compliant.
