Hey guys. Just purchased some 350z 18's and would like to know what the
widest tyre i could go on the rear due to the offset they have. I was hoping
to get a 265/35/18 for the rear's but not sure if i would run into any trouble.
Any help would be appreaciated. Thank's :happy:
https://www.sau.com.au/forums/topic/156810-who-has-350z-18s-on-there-r33/
hey mick, no luck with the guy at work in reguards to tyres.
Good to see your finally got some wheels for the beast :/
Post up some pics when they're on.
or better yet, come round and take me for another spin :(
are your guards lipped/rolled?
simon
Any help would be appreaciated. Thank's :P
hey dude i have 350z 18s on my r33
i run 235/40R18 on the front
and 255/35R18 on the back
they are 8 inch wide
i tried to put 275s on the back but where to big scrubed out
all the time
might be lucky with 265s but 255s fit sweet
hope this heaps
This help's alot. Thank's heaps BEN O.. :domokun:
BEN O do you have traction problems with 260kw?
Also what type of tyre's do you have. Thank's
bridgestone potenza so3 on the front, very expecive
Falken ziex on the rear bout $250 each.
less than 50% tread no traction reving out in second gear
otherwise 255s give excelent grip.
Hey Duncan. Do you think i will fit 265's under the 33? Also what sort of price are the Falkens you have.
Ive rung a couple of places and the options so far are: Maxxis Mav's $318, Sumitomo $310 and the
Hankook K104's for $300 each. All these were in a 265/35/18. :laugh:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
