Okay i have done a search for hesitation and loss of power, but none of these have helped me.
The car as you can see in my sig is a 33 s2, mods are,
3inch from turbo back,
FMIC
spiltfire coils
walbro fuel pump
boost controller and
pod filter.
Now my prob is when i give it a boot full the motor seems to "struggle" until it hits about 4-4500rpm, boost is set at 8psi, so my initial thought is timing playing up... as once the variable timing kicks in at 4000rpm or 4500rpm, whichever one it is, it is like boost kicks in and you get full power again. This is in atleast 1st, 2nd and third gears so assuming it does it in all gears. Coil packs and spark plugs are only 2mths old so i don't think it is any of them as its not a miss.
It feels as though i've lost power as the car takes forever now to get to 4000rpm, but as stated before once it hits 4k it like the turbo kicks in. IT is the standard turbo by the way and i have full boost by 3000rpm as the boost controller bypasses the factory solenoid. ECU is also stock. Maybe my CAS is playing up??? or my O2 sensor, these are things that other people had problems with that i found in the searches i did, but the problems these people had aren't the same as my problem.
Its like when a N/A motor struggles in the top end of the rev range, like when the carby isn't supplying enough fuel or not flowing enough air, but i can't see it being a problem with the fuel as the pump is also 2mths old and once it get past 4500rpm it goes all the way to redline like a scalded cat.
This has only just started to happen in the last week or so.
Any help would be appreciated
Cheers Adam. :happy:
https://www.sau.com.au/forums/topic/156813-rb25det/
  Devils_Advocate21 said:
Ummmm have you changed anything in the last week or so before the problem, may have direct connection to the source of the problem
Nah nothing, also don't think it is a bad batch of fuel as its had a couple of tank fulls since it started.
https://www.sau.com.au/forums/topic/156813-rb25det/#findComment-2913367
in most cases when people complain about their rb25's runnin sick its usually directed at the ECU playing tricks with timing etc (like you said). This usually doesnt effect the bottom end power what so ever. It has the same symptoms as what your describing, like it feels like your towing a boat. I'd start with the simple things. Try by gapping your spark plugs to .7mm but usually this doesnt effect anything under 9-10psi but give it a go anyways. Then maybe get a timing light and sus out what static timing your CAS is set at.
https://www.sau.com.au/forums/topic/156813-rb25det/#findComment-2913386
Sorry should have posted plugs are gapped at 0.9mm, i don't think going smaller will fix the problem, as stated i have splitfire coils and 8psi so should be heaps of spark. As stated before also plugs are only 2mths old and have been gapped at 0.9mm since new, problems has only just started in the last week or so.
But yes i think i'll try the timing light and see what it is.
https://www.sau.com.au/forums/topic/156813-rb25det/#findComment-2913407
Im very curious as to what this could be.
Just to clarify:
1) After u hit boost 4-4500rpm, does the car pull as hard as it used to?
2) How long ago did u do ur boost controller?
My opinion is that chances are, uve got urself a boost leak (mayb from the boost controller instal).
On a stock turbo, u should begin spooling at around 2.5 and be at full boost by before 3.5. If ur not hitting boost till 4.5, this would indicate that ur leaking a significant amount of psi.
After u start to get positive pressure in the throttle body, the car will feel normal. You should be able to realise this is happening if its happening because ur hear ur turbo spooling while ur gauge is still reading 0 or below.
https://www.sau.com.au/forums/topic/156813-rb25det/#findComment-2913433
Just to clarify:
I hit full boost by 2700-3000rpm, boost controller was done 6-7 mths ago, what i was trying to say was the problem feels like i hit boost at 4500rpm , thats how it seems, but i hit full boost by 3000rpm, as stated all stock turbo, ecu and psi.
Once past 4500rpm the car pulls just like it use to, but before that it struggles so to speak.
https://www.sau.com.au/forums/topic/156813-rb25det/#findComment-2914404
  MBS206 said:
What boost controller are you running?
GFB dual stage, low boost is set at 8psi and high boost at 13psi, though i don't use high boost at the moment, not until i get the PFC in. And no switch isn't set on high.
https://www.sau.com.au/forums/topic/156813-rb25det/#findComment-2914429
man this stuff happens to mine
heres my answer of what i've noticed ok.. :P
first time it happens = played around with idle screw just for fun? it fixed it up ( just luck ) :P
2nd time it started happening = rich and retarded ecu shit itself got a new ecu everything was fixed no lag before 4 thousand rpm
3rd = right now...... using idle screw adjust to allow more air has kinda made it better but not quit still it does it, :laugh:
try da idle screw? all da way low den keep adjusting? mite fix?
or else go and buy a new ecu for 50 bucks and it'll work normal <---
till it stuffs up again so maybe get ur ecu tuned??? thats what im doing now , i hate my stock ecu shitting itself all da time :(
of course its from running higher boost
https://www.sau.com.au/forums/topic/156813-rb25det/#findComment-2932227
Sounds like the ECU is in failsafe. Engine is breathing far better than stock, so it serves up a massively retarded ignition map to discourage any behaviour thta might damage the engine.
And as pointed out, changing the ECU may give a cure but it will be (very) temporary.
Many people (myself included) have hit the same hurdle by adding intake/exhaust/FMIC alone - no boost increase. And it is frustrating.
https://www.sau.com.au/forums/topic/156813-rb25det/#findComment-2932296
Likewise. PFC opened the performance lid for me.
In some ways it's a pity the R33 ECU is too difficult to alter. The results being pulled from R32 spec remaps are very noteworthy.
Whether PFC is becoming scarce, the options are still wide open. :wacko:
https://www.sau.com.au/forums/topic/156813-rb25det/#findComment-2933161
yer dude I had the same problem I lived with the problem for about 4 months then I got myself a cheap pfc and bang the basic factory default maps on the pfc worked fine fixed all the retarding the stock ecu was creating I feel the extra power much more now best invesment I ever made buying the pfc go apexi!! :D
https://www.sau.com.au/forums/topic/156813-rb25det/#findComment-2933830
  • 1 month later...
Hey just changed my fuel filter and you should of seen the color of the fuel that came out! it was black!!! car was starving of fuel, now all is okay. man i'm glad i fixed it now and not after the thing leaned out to the point of blowing something! :)
https://www.sau.com.au/forums/topic/156813-rb25det/#findComment-3010552
did that help also Adam?
I found with mine, my car was running similar to how you described.
I had standard fuel pump though and was cutting out - couldnt handle the new power levels.
Now, I got a walbro also and the powerFC and tuned - car has felt freakin strong since, but only this evening, went to start it after a few dyas of not using it, and cold start - splattered and splurred - but after a few mins was back to normal.
Hurry up and get it tuned!!!!!
https://www.sau.com.au/forums/topic/156813-rb25det/#findComment-3010630
    • Ok guys thank you very much. GCG highflow it is then 馃檪
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
