ok guys basically this once beautiful 32 gtr met its match, a fence...
the car is a write off luckily however the whole running gear and most of the parts except for panels are in perfect condition interior engine gearbox brakes all that is good.
the interior looks a bit dirty in the pictures cause it slid through a bit of dusty grass but its all good.
the car had 102 kms on it.
it has after market coilover suspension which were on it when i got it so i dont know the brand and havent looked but they are blue and ill find out 2morrow
it has a 3 1/2 inch exhaust from front pipe back ( stock dumps )
the damage on the front isnt that bad, the intercooler copped it sweet and the radiator is probably axed but everything back from that is sweet as.
basically im looking to get rid of the whole thing for something in the $8000 range, and if i dont get any offers i like ill start offing the thing in parts, so basically ill wait a few days and if nobody wants the whole thing ill repost with a parts list.
this thing is perfect for someone who has a nissan that isnt a gtr and has rb26 aspirations or someone who wants an extensive spares range for their existing gtr :happy:
im also considering putting the 26 in my gtst if the whole thing doesnt go.
feel free to come and check it out.
the steering wheel is gone from the pictures, the rest is all there.
im also selling a fibreglass gtr bonnet which i had planned on putting on but didnt
picture at the end $600
if ur interested please contact me by phone, u can msg here if u want to but dont expect punctual replys.
0406305069 Call anytime.
its my gf's phone so expect a girl to answer im between phones atm my name is Jason.
but yeah heres some pictures, warning, some pictures might upset some people, they break my heart every time.
Edited by ODessA
https://www.sau.com.au/forums/topic/156815-32-gtr-wreck/
hey dude im keen on ur seats bonnet and the interior trims around the rear quarter glass, also the passenger side air vent, the front bar looks like it got raped but if im mistaken let me know. :)
https://www.sau.com.au/forums/topic/156815-32-gtr-wreck/#findComment-2913754
hi FIRST DIBS on the the exhaust system, cat and cat back and alsow il grab the strut brace let me know if you are going to sell the parts?
and also let me know the price for the coilovers. :)
https://www.sau.com.au/forums/topic/156815-32-gtr-wreck/#findComment-2914417
listen guys im hoping to get rid of it as a whole, as yet i havent had a offer im happy with and if in the next couple of days i dont get one i will dismantle the thing as parts, if that happens i will contact all the ppl who have msged me for parts in the orders they msged me and sort it from there, so feel free to ask for stuff, and if i dont get an offer, and u were first to ask for somethign, u will prolly get it.
thanks guys.
https://www.sau.com.au/forums/topic/156815-32-gtr-wreck/#findComment-2914980
If you do decide to sell it as bits I'm after the rear drivers side trim piece, front mats, rear view mirror and passenger door trim. Let me know.
Thanks
https://www.sau.com.au/forums/topic/156815-32-gtr-wreck/#findComment-2915938
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
