Hey Peoples,
I am having a little dilema with my R34.
My Battery light is staying on. I have checked all fuses and none of them are blown, my battery voltage guage is staying put on 16v. It doesn't change a bit when turning headlights on/off.
I have continuity from the Alternator - Fuse - Battery +
My multimeter is playing up so I couldn't get an accurate voltage reading, but the ohms is working ok.
What sort of voltage should I be getting at the 2 pin connector that goes to the regulator?
I drove the vehicle for roughly 2 hours with the light on, and it started fine, no change in voltage reading.
Anyone have any ideas / suggestions?
Cheers
Josh
https://www.sau.com.au/forums/topic/156821-battery-light/
try the consult default code link, its here somewhere, search, the computer give a fault by flashing a light so many times, it goes somewhere along the line of turn it on and pump the brake 3 times and turn the wheel, but its not that.
https://www.sau.com.au/forums/topic/156821-battery-light/#findComment-2913858
