hey all just want to know what the max boost a rb25det can handle regarding just the motor its self...
atm it is running about 1.5bar with a t70 turbo and all is well, just want to know if that is safe
is the motor capable of more boost or is this about it???
no pinging and no leaning out, so far :)
Cheers Acea
https://www.sau.com.au/forums/topic/156840-rb25det-max-capable-boost/
Its not about how much boost can it handle its about how much power it can handle on stock internals. What power are you making at the moment? Then we can give you a basic guide to what is generally considered safe on stock internals. Around 250-260rwkw for longetivity of engine.
cheers for the fast reply
heres the full story... me and a mate have been building his 32 rb25det for ever and have logically progressed to the point where right now after getting a 3in put on 3 days ago the 38mm gate is to small to bypass enough gas. so with the wategate connected straight to the manifold it spikes at 1.5 and drops to about 1.35 in 3rd. where as before with such a restrictive exhaust the max boost it would run was about 14 psi with the wastegate connected to nothing or the boost controller set to max.... being in wodonga and both working full time its going to be about 2 weeks before we can install a tial 44mm gate or something bigger (unsure if 44mm gate is enough?)
it made 200rwkw with old exhaust and i think now at 1.5bar and a free flowing exhaust its probably pushing 250 ish (really unsure? +or- half a brick) but the stuck in the seat factor has increased considerably and it breaks traction in 3rd...
just need to know if 1.5bar is ok untill we can change the gate and get it back on the dyno for a tune
cheers acea
AFR's are sweet thanks to a wb02 kit :) we have the computer mapped for a z32 maf but are using the r32 one to put the comp into saturation so at full noise and 7k its running about 11.5:1 (as soon as we are happy with the boost controllability its straight on the dyno for a re map and some timing)
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
