Having likely found the wheels to get, now the question of tyre size arises.
OEM tyres on a S2 Stagea is 225/50/16 which gives a diameter of 631.19mm
Looking at 18" x 8" rims
Possible tyre choices (based on 1010tires.com) are:
225/40/18 - diameter of 637.03mm
235/40/18 - diameter of 645.16mm
245/40/18 - diamater of 653.03 (per tyre retailer)
245/35/18 - diameter of 628.65mm
Therefore based on the above, it seems the closest tyre would be the 245/35.18 and then the 225/40/18 (although have noticed in previous threads that the 225/40/18 seems to be the recommended tyre size).
Will check with dealer on the 245/35/18 size. The tyre retailer also stated that the 225/40/18 would be too small in overall diameter whereas the above suggests it is actually a larger diameter than the OEM version.
For those who are running 18" rims (or just know this stuff) can you advise on what tyre sizes you are running and whether you have noticed any problems?
Any help woule be appreciated
Cheers, Al
https://www.sau.com.au/forums/topic/156856-help-with-tyre-sizes/
if you HAVE to base it on that
I dont listen to tire manufacturers
they tell people things dont work becuase most people are retarded and do stupid things.
225x40
if you want to go lower you can go 215/40
but some people think its unsafe. its not.
But hte need to go with a smaller tire has to do with a few things
First
How low is your car?
Im running small tire sizes becuase i like to tuck tires in my wheel wells.
if you dont need to do that
go with a 245 or so its "Safe" or whatever
but larger tires on 18s looks funny. and it will make your car sit higher.
Edited by yokotas13
Hi Alan,
Pretty sure you are asking the question in regards to keeping your speedo accurate (which is very important in Australia Grant) and you are dead on the money, the 225/40/18 is the closest you can get to the factory rolling distance in a standard 18" tyre. Although the 235/45?/18 is a more common size and can be a lot more cost effective solution without getting too far away from the factory rolling distance.
You can use the following page to work out the difference between the sizes.
http://www.carbibles.com/tyre_bible.html (scroll down a long way).
I have a S1 running 225/40/18 tyres and under the freeway speed check I read 97 when sitting dead on 100km/h so I am happy with that size.
Cheers
Luke
Luke, yeah it is in relation to speedo accuracy to get the closest to the OEM diameter
Logan, my tyre placard has both the 205/55/16 and 225/50/16 on it and I have the 225's on there at the moment
So still divided opinion it seems :)
why is the speedo so important?
Keep a second set of wheel so when inspection comes around, you have a stock rolling diameter wheel.
i do it. its important in japan too
spedo is important here grant because unless u run a gps all the time im buggered if ill fork out the huge dollars for speeding fines here in nsw and believe me ive been done for 5 bloody klm over the limit.not in the stag tho was by a fixed speed cam
As Mike said depending on other things, you can get fined for 2kmh over the limit in WA so having it as close to OEM is a factor over here.
So it seems a toss up between 225 and 235's without any mention of the 245's - would 245's actually fit?
I have 18X8 and 235/40's fitted.
My speedo reads pretty much spot on (+/- 2km/h).
I also am not a fan of the stretched look with tyres. I like it when the edge of the rim and tyre are even. The stretched look just makes it look like you are too cheap to buy a set of proper width tyres (IMHO).
I would have liked 245's, but I heard that they don't fit very well on the front.
but the problem is you guys ar emissing the point and advantages of streching
i wont get into it, but its just not for looks. and not only for fittingh tires. there are performance advantages.....
but then again id image most stagea owners really arent worried about handling (not being derrogatory, its 3700 lbs car lol its not ideal)
either way, any of your options are viable, some will look remarkabley differnt than others and fill up the well more.
I'm running 245/45/17, they fit nice, plenty of room inner and outer. And the speedo is more accurate than standard (checked to GPS speedo).
Don't forget ADRs allow speedos to read up to 10% higher than actual speed (so you may be going slower than you think)
Correct. I found using GPS that my speedo is about 4km/h optimistic, which is good in a way because I at least know that when I think I'm doing a certain speed, I'm actually travelling below it, so I won't get any grief from Cops or speed cameras, etc.
The speedo on my old man's Camry, however, is VERY accurate when compared to GPS readings!
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
