hey guys just trying to get some ideas on which head gasket i should use.
its for a rb26dett
forgies 86.5mm and also what engine gasket set to get ?is it worth getting all the gaskets individually as i wont be needing the standard nissan headgasket that you get in the kit.
cheers guys johnny
I think Tomei do full kit with 1.2mm metal head gasket and metal gaskets for inlet too I think
Definitely don't buy the gaskets individually.
For example..
I bought a gasket kit for the rb25 head for $270.
It came with all top end gaskets and valve stem seals.
IF you were to buy just the valve stem seals by them selves Nissan want $330!!!!!!
Theres an 'unbranded' nissan gasket set you can get....cant remember the name of it, its not one from nissan, but more like the contents of a nissan kit (every genuine nissan gasket not cheap shit ones) with a different brand name on it. They cost a bit under 200 from memory..
Comes with a standard head gasket, but just buy your own and sell the nissan one.
Works out cheaper than the Tomei kit.
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
