  • Replies 153
if it is posted here it is open to anyone :laugh:
The more the merrier...
However in saying that im not telling everyone as i want more than 3 runs and dont want all of Brisbane to show up... >_<
For those who dont know the prices or have not been to willowbank before for one of these events below is some inportnat info...
Cost:
Competitors: $36 to race, admits the driver and one other.
Spectators: $18 adults, $16 students with ID
Children 13 & under are free.
Time:
Saturday Events - Gates open at 4pm and runs commence at 4.30pm, so we want to be there at 3:45pm to ensure a quick entrance and we can start racing straight away before a commodore hits the wall and halts racing for an hour will they clean it up... ;)
To run at these events you need:
Requirements for a car - helmet to Australian Standards, long sleeve shirt, long pants & covered shoes.
Cars can not run quicker than 10.99 sec
so shall we make it sat march 17th then?
This topic is for the 3rd...
Start a new thread for the 17th, if people wanta go on the 17th then they will go on the 17th and like wise with the 3rd they will post here, me personally im going on the 3rd as i have already coxed a mate to run his SS ute and as i said i cant wait to get out there...
Good idea col
Im going on there 3rd because a group of friends are going then
This suxs
I just found out today that work is sending me up north for a week or so from the 1st of march . So I wont even be able to the 3rd my self now god damn it
maybe we might change it to the 17th now becuase I might give people more time as well
What do you think ??
As I said to Warren, no reason why we cant go to both...
Im still going for the 3rd reguardless as im tto keen to get some numbers on paper... :P
But as i said in the 17th of March thread, ill probablly coax Nay to take the S15 so ill be there anyway...
hi all. ill be in for this.. on the 3rd. but i need to borrow a helmet or two.
dont think ill drive my GTR.. hasnt seen a track yet and she dnt need to.
will run my mates S14a and maybe the R34.. yay auto...
so if someone could lend a few helmets then im in :blush:
try cash converters.. you will be surprised
last time i went in they had some good nam helmets at cheap prices
as long as you check that its not cracked or doesn't look like its hit the ground before you're laughing
I did the cash converter thing and the cheapest lid they had was 150 bucks. robbin bastards. :happy:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
