  • Replies 153
  WazR32GTSt said:
try cash converters.. you will be surprised
last time i went in they had some good name helmets at cheap prices
as long as you check that its not cracked or doesn't look like its hit the ground before you're laughing
ahha hit the ground and blood on the helmet.. woah..
if someone wants to buy a $64 helmt ill give u $65 on the drag day.. i ahev an average size head lol :D
  silverbulletR33 said:
Last time i was there , there was cars running in the 9 second bracket on test n tune night, Hopefully well see more of that this time :thumbsup:
True, but they need a licience for that and a bunch of other saftey requirements...
As for the people like us who like to drag one in a blue moon and have no special liciences we need to keep it slower than 10.99 seconds...
well you'll have no worreis about runnin 10.99 or quicker col :)
  Col-GTSX said:
Im in stone Noel...
Pleased to hear it col. Wonder if you could do me a favor. Do you have a dyno readout close to the specs you will run on the night. Would love to have a look at your curves. :laugh:
  markimak said:
oh i can defently borrow ur helmet noel.? i think ill buy one if u can pick me up one too. ill pay u the amount let me knw.
thanks noel
mark.
will pick one up forya marki. no sweat dude.
  FineLine said:
sounds like a few liners will be there. we better meet and pit together somewhere. What time will everybody arrive.
Ill be there at about 3:45pm... Ill be heading straight to the staging lanes...
I have invited 2 of the pro channel guys from work to come and shoot the event for us and they have got a couple of very expensive lens's out on loan so the pictures from the night will be fantastic... So make sure your cars are clean and shiney...
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 馃槢 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
