Well the RB20DET (R32) is an all round good performer and has rather strong internals, so can handle like up to around 240rwkw with the standard internals.
With the 180SX's, they came with the CA18 and the SR20. In my opinion the SR is the better of the two engines and response better to mods, even over the RB20DET in some instances. Both the 180 and the R32 handle excellent, but if had to choose the 180 would be slightly better with handling. But what won me over when i bought my R32 was the appearance. It looks so much more stylish than the 180.
As for parts, there are lots for both...so no problems there.
For further info about the R32 GTS-t, do a search on here or visit www.meggala.com
Best thing to do if i were you would be to test drive a couple of each to see which you prefer.
Regards,
Scott.
They R both pretty evenly matched. Don't underestimate the powa of the CA18 - yes in terms of build i don't think its as strong as the all alloy SR20 - There was an article in Zoom magazine (no9 i think) Where a CA18 180 pumped out 300+ Kw's @ the wheels so its definately capable. In Japan tho these cars are greatly considered as Drift cars as opposed to drag. RB20 is a straight 6 and the CA18/ SR20 are 4 cylinders. Still I have a couple of mates who get chopped just as easily from a mildly modified 180 in their R33's which have around the same power. But when you're talking a bit of drag you'd prolly go the SR20 coz of its responsiveness and internal engine strength.
In one of the older HPI issues they did a comparo between r32 and silvia,which has similar(identical?) performance to the 180sx.Based on their times,r32 does 0-100 in mid-high 6s and 1 1/4 mile in mid-high 14s.Silvia does low 6s and low 14s so its faster.The same article mentioned that despite being slower the r32 is in a different class, compared to s13 cars.The engine I belive is stronger stock for stock, and,unlike sr20 doesnt have problems with extended high rpm work.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
