Hay guys, dam this hot weather, So dam hot it's not funny.
Anyway i have not been able to get higher then 12 psi on my stock turbo. Is this a heat issue? I have a FMIC, but 35 deg plus is ttoooo hot.
I readjusted the boost controller, but no good, can't get higher.
Is this a common problem. I have had no issues when cold, but today is the first hot day and hence my question.
[Hay guys, dam this hot weather, So dam hot it's not funny.
reply
hey mate ive noticed in hot weather my car's turbo doesnt as well, but i think its because my pod filter is closed up, so i think the added heat makes it a problem, if u hav a pod try n get a heat shield that should fix the problem
Hey
I'm sure that you know that the car won't run very well in the heat (you do live in the heat after all, lol). Mine runs liek crap.
But in answer to your question, nah, the heat won't stop you running high boost.
It's most likely the boost controller you're using.
Just to give you an example. If you disconnected the vacuum line from the waste gate actuator - so just leave it out in the air, and floored it, it'd probably hit 50 psi or something (don't try it or you'll blow the turbo and maybe your engine.
the stock turbo runs outta puff after 12psi anyways, i dont know why you'd wanna try put it up boost on a bloody hot day aswell...i can see alot of people shaking their heads right about now. you said your well aware of pinging etc and you say its fine, but most of the time you cant hear it pinging.
she wasn't pining, well not till this morning, i added soem timming. Backed off REAL Quick.
This morning much cooler temps, but turbo still seams funny. I checked it and there is no shaft play, well no more then the specs say, all good there.
Going to check engine compresion to make sure.
I am using a gozzmo IBC. I am also going to put my 10 psi actuator back in, that seamed to work better.
I tell you what, these turbo cars make me VERY paranoid. Knock, ping, bang and so forht.
hence why you leave things on the safe side especially in summer. Lowers the chances of it going Knock, ping, bang and so forth.
If you wanna go nuts with boost and timing in summer chuck a water/meth injection kit on it.
Thanks mate, i am in the process of making up some FMIC cooler water kits, and possibly injection kits aswell. For now i just need to back of a bit. LOL
Also, how much differance does a heatrange change in a sparkplug make. I have BKR6EYA, but thinking of swapping to BKR7EYA.
The reason i want to do this, is that i have a Central 20 ecu, and has been tuned with safc to get correct air fuel ration and some timming knocked out, but i still get some ping, well i think anyway. So possibly going to a 7 hetrange plug could help a bit?
Edited by WogsRus
Nothign wrong with it, simply put the stock one back in to get the EBC tuned to that, problem is that my wastgate still is stock and couses creep. The 10 psi gate is much better, so i will be switching to it.
It works much better with the 10 psi gate, it is just for tunning purpouses for the EBC.
Main problem since the weeknd, lack of boost over 10-12 psi, well not lack of but harder to get to that level of boost.
So i'm gona do some more research
yeh a colder range plug will drop knock a little bit...but not alot. From memory from what cubes informed me ages ago it was equivalent to 1 degree of timing pulled out i think or something along those lines.
tune your ebc for cold AND hot. Does it have two settings? If so retune for both weather conditions as stuff like gain etc etc will be different for different temps
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
