  • Replies 59
Nice shots! Im still learning on this phone my gona try and master the Panorama shots as it's only my first time..
f**kin awesome effort for ur first time man..
im yet to do one..just cause it simply takes too much time :/
Hmm yes wouldnt mind that at all ill hold that one at the moment got a few things coming up
awesome day
awesome pics
<--- new avatar thanks to nismo
Adam, i must take you for little drive around tambo... just to show you some roads and where they go...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
