Hi guys, it's time to get back into something AWD so my R32 is up for grabs. I've owned it for about 5 months and in that time i've added Recaro seats, 4pt harness, custom tailshaft, alloy radiator, and had it tuned.
1993 R32 GTST Type M
114000k
Rego to June 07
210rwkw@16psi, 240rwkw@21psi
Engine:
RB20DET
Microtech LT12s ecu
Garrett GT28 0.86 440hp turbo
Custom modified exhaust manifold
Genuine Hybrid 600x300x75 FMIC
JJR 40mm alloy radiator
GTR injectors
Custom dump pipe
3" turboback exhaust
Malpassi FPR and gauge
Bosch 910 fuel pump
Custom cam gears
HKS air filter
Greddy Type S BOV
Driveline/Suspension:
RB25DET gearbox
Button clutch
Custom 700hp rated tailshaft
Tein HR coilovers
GTR rear swaybar
Hicas lock
ANZ 18x8.5" rims with 235/40/18 tyres all round
Extra 17x8 and 17x9 Impul rims
Interior:
Greddy Profec B boost controller
Greddy Turbo timer
Autometer boost gauge
Blitz steering wheel
Razo pedals
Recaro driver and passenger seats
RPM 4 point driver's harness
Pioneer DEH-P9650MP headunit (RRP~$1400)
JVC 520W 4ch amp
Sony 6" front splits
Pioneer 12" sub
Pioneer 6x9" rear speakers
Asking price is $16500.
Less $500 without Recaros (stock seats fitted).
Less $500 without stereo.
Will consider removing other parts to reduce price.
Located on the Gold Coast, please PM me or email [email protected] with enquiries.
Edited by neil_se
https://www.sau.com.au/forums/topic/156926-modified-r32-gtst-qld/
  • 3 weeks later...
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
