  • Replies 175
hmm go racing with guys or celebrate 1yr anniversary with my gf...?
think ill go on the 3rd
Under the thumb mate LOL.
Bring her along and buy her a hotdog you can have dinner in the stands at willowbank watching Skylines race.
PERFECT.
here is a good opportunity to prove that the dyno today was bogus :wave: MPH doesn't lie!
So true.
Does anyone know how strict they are with running 4 point harnesses if you crack the 11.99.
Am hoping.
So true.
Am hoping.
They not at all... Unless you break the 10.99 they dont really care...
Last time we went out i saw a guy at the bottom of the tower giving a bloke all the info he needs about getting a right paperwork and licence's for next time he comes out. The guy ran a 10.60 and he just said I wont bother, I wont come back... :wave:
So in short they dont care until you break 10.99... But once you do, there is no point in returning until you have a harness and a cage, oh and tail shaft loop if deemed nessary...
All the info is on their website...
Yep sounds good.
Come on Col i want to see you run the 33 not the s15.
It shouldn't. According to the dyno on the weekend I only have 150rwkw and I have managed consistent 13.9s - 14.0s.
I know I have a 33 but they aren't that much different. and a mate of mine has a 34 sedan tiptronic with around 170rwkw and he has done low 14s.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
