hey guys/gals im wondering how much rear wheel kilowatt do u need to achieve a high 12 second pass down the 1/4 mile in a r33 gtst?
im curious to see what ppl come up with cause i have no clue.. i know the driver plays a big role too.
if u can guys plz post your times with the power you made at the wheels
cheers :/
https://www.sau.com.au/forums/topic/156968-how-to-achieve-high-12s/
  • Replies 70
200rwkw
drag radials
suspension work
prefect launch
prefect conditions (high track temp)
250rwkw
drag radials
suspension work
ordinary launch
good conditions
Pretty much spot on
But if you cant (as most people on a budget cant afford em) buy drag radials, make sure you set your tyre psi much lower then normal.. I think around 20psi?
Also, remove all the rubish that will slow you down, like subs, amps, spare tyre (leave them in a mates car just incase you blow them), rear seats (for the wank factor), ect ect..
Edited by DjeMz
My post is based on times i've actually run in my car which is the same as the one in question. I have seen absolutely no reason to upgrade a diff to achieve these aims.
fair enough :( not all skyline are the same, i've just found that my diff may be letting me down
' date='19 Feb 2007, 02:46 PM' post='2916198']
112mph wih 251kw and 13flat 1/4mile time
reason y im asking this is cause my tuner thinks i can only make 210 atw if im lucky due to my mods.. i thought i could make more tell me what u guys/gals think?
pfc, fmic, hiflow turb, stock injectors, 040 f/pump, 3in turb back exhaust w hiflow cat, k@n pod
car has been lowered from japan but there compressed springs.
True. If you're diff is open-wheeling (spinning one leg) then it should be repaired or replaced. Fair enough.
it's your injectors that are gonna let you down. All the other mods can get you to 250RWKW. The standard injectors run out of puff at around 210 to 220 max. CAMS, injectors and Z32 AFM will get you to 250 easily..........dependent on the quality of the hi-flow
its the sliding hiflow that ive got.. how do they compare to say GCG?
i only bought it cause it was cheaper and has to be better than stock lol :(
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
