hey guys started today fasting for lent, well kind of lent anywho.
i have 40 days now of eating nothing from an animal which has blood from it supposedly.
(dont know the exacts but thats what the old greeks are telling me)
anyways i will post up a steady update and how i am going every now and then,
and maybe how much weight i have dropped :D
all the best and GO VICTORY!!! cyas
wish me luck lol :sorcerer:
https://www.sau.com.au/forums/topic/156973-arghh-fasting/
  • Replies 41
mmm im having lunch now sausages n bbq meat mm the fatty goodness lol yeh when i fast for ramadan its no food or drink wat so ever so count ur self lucky u still get to drink water and eat other foods... ramadan is alot harder lol
https://www.sau.com.au/forums/topic/156973-arghh-fasting/#findComment-2915698
and maybe how much weight i have dropped :(
yep same here, i'm only doing it for a week or 2 though :happy:
https://www.sau.com.au/forums/topic/156973-arghh-fasting/#findComment-2916220
Personally i think fasting is easy.
I fasted at ramadan and the first day was the hardest for me, but after that it got easier.
Just don't think about it, get on with your life, and dont do too much physical activity and its a breeze.
Good luck. :P
https://www.sau.com.au/forums/topic/156973-arghh-fasting/#findComment-2917198
why didnt u choose something easier to do...like what that guy did in "40 days and 40 nights"
What build a wooden boat and stay on the water with 2 of every animal, then change his name to Noah :P
**Edited - you mean a movie, not too good on those things! :huh:
https://www.sau.com.au/forums/topic/156973-arghh-fasting/#findComment-2917220
**Edited - you mean a movie, not too good on those things! :)
hahaha yeah....that movie where he has to refrain from doing anything thats remotely sexual....if gtsr22 did that....this thread would be filled up with pics of hotties and his days of lent will be over in no time :huh:
https://www.sau.com.au/forums/topic/156973-arghh-fasting/#findComment-2917245
    • Thanks heaps Duncan and GTSBoy. I'll get my old man to sit in the driver's seat and turn it on and off while I test with the meter. Or maybe other way round, depending on whether he remembers where his glasses got to
    • This is the GTR fuel pump. Yellow shows 12V, orange shows earth. The ECU provides the earth to activate the fuel pump relay. The ECU side of teh relay will pull low when the ECU activates. This is the RB20 fuel pump. Almost the same, but a little simpler. You can see I indicated (above) where the 12V line goes down to the RB20 diagram on the overall diagram, whch shows both RB26 and RB20. This is where I show it coming in on the RB20 diagram below. You can see that the dropping resistor is handled differently. When the fuel pump control is not providing earth to the pump, the pump earths through the dropping resistor and thus runs at lower voltage (some is wasted over the resistor) and runs slower. I showed that "not 12V and not quite earth" portion of the wiring in a paler orange. The rest of the wiring that I did not colour on that little section below the pump would be orange when the fuel pump coontroller is providing earth. This drop is handled inside the fuel pump controller in the GTR. Regardless, you can see where 12V is supposed to be, where earth is supposed to be. The key on prime is via the ECU providing the pump for only a few seconds the switching off. You should be able to see that happen.
    • Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs.  One trigger pin should be either fully earthed  The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
    • All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a  multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
    • Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
