Due to some other cercumstances I am selling my car. (house that needs work and I want a new trail bike)
list of mods
$24,000 firm
R33 GTST 95 model Type M
AB Flug body kit and steering wheel very rare and unique.
Volk's 18's 235 and 265's on rear "CF Challenge"
Olims fully adjustable suspension
rose joints on front
Cusco front and rear strut bar
Splitfire coil packs.
Custom Front mount with heat rapped ic piping.
Apexi pod filter
Apexi exhaust system from dump
Apexi BOV
4" magic Cat
CF bonnet
Remaped Nerve essential ECU
HKS 25/30 turbo woot 18psi at 2800rpm
Ratchet cusco locker
Organic 1500kg clutch
Walbro 500hp pump
malpassi rising rate Reg
Blue light dash
Apexi RSM
Greedy Turbo timer
Greedy boost gauge
Rebuilt Gearbox
Exhaust manifold gasket changed and bolts upgraded.
240rwkw on 18psi
DBA4000 slotted fronts
Braided Break lines / clutch. approved by Australian Standards
Car weighs in at 1260kg
3point alarm
Stereo Mini Disk and CD player / graphic equalizer
sony 2channel amp / splits / 6by9's in the rear next to the seats.
I will be fixing the body kit as the front has some cracks in it.
All major work has been carried out by Trojan motorsport
Serviced every 5000 or 6 months. I am the second Aus owner. The car was personal import from Trojan
who owned it before I did so they have the full history of this car.
85000 K's on the clock or there abouts.
No tire Kickers No joy rides No P platers
PM for phone number if your keen to have a look.
Photos to come. When I have time.
Edited by race_snooze
https://www.sau.com.au/forums/topic/157009-its-time/
Wow i honestly couldnt see you selling that car it is awesome. I must say this is one of the nicest R33 gts-t's in Canberra if not the best. I am yet to see this bodykit on any car any where else... again just to re-iterate this car is awesome... someone buy it and help snooze out.
https://www.sau.com.au/forums/topic/157009-its-time/#findComment-2916267
IMO this is the hottest 33 in ACT, cant believe your selling though shaun :( :(
Goodluck for the future though, maybe buy a 32 abit later on down the track (you know, a REAL skyline :huh::( )
P.S. why's everyone sellin up and shippin out? :(
Cos you keep dissing them, your too hard, like katana steel!!! :wave:
https://www.sau.com.au/forums/topic/157009-its-time/#findComment-2918104
P.S. why's everyone sellin up and shippin out? :wave:
Making room for some new blood to enter the scene i spose.
Im frankly sick to death of spending money on the thing and spending a house deposit every year just to live under someone elses roof and making them rich. So time to get my own.
https://www.sau.com.au/forums/topic/157009-its-time/#findComment-2918386
smart thinkin dude.. im getting rid of my line in bout a month aswell, had enuff of spending cash on it, too much maintenance, gonna consider investing in a house.. maybe after i pay it off a bit in the future get another line..
https://www.sau.com.au/forums/topic/157009-its-time/#findComment-2918509
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
