Attesa Ecu Fault Code 13
shaddie
 Share
Does anyone around the Wollongong area have an ATTESA ECU which I could borrow for a few minutes?
My unit is flashing error code 13 which, according to the service manual, could mean the G-force module is faulty or the ECU itself is stuffed.
I've followed the service manual and that's as much as it tells me. If I could borrow and ECU I could prove it one way or the other.
If anyone out there has fixed an "error 13" problem WWITHOUT changing the G-force module or ATTESA ECU... please let me know.
  • 3 months later...
No need to start 3 threads about the same problem......
I'm nowhere near the gong but if you come to the show n shine on sunday we might be able to sort out something.
But start by taking off your centre console and have a look at the g sensors (gold box) there is a window at the front which will tell you if your g sensor is dead. And while you are there make sure both plugs going into it are ok
 Share
